Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
LinuxAMD64 version of java is actually 32 bit
Old   October 19, 2007, 03:56
Default While installing OpenFoam on a
Mark Brandon
foret37 is on a distinguished road
While installing OpenFoam on a Linux 64 bit machine, we discovered that the java binary packs for linux 32 bit and linux AMD 64 bit, as distributed at the OpenFoam site, are EXACTLY the same. Some more examination revealed that they are both 32 bit versions. (Note that there is no AMD 64 bit binary available at Sun for this version of Java.) This mix up may account for the problems some people have reported for installations of FoamX on Linux 64 bit machines.
The two identical files are:
j2sdk1.4.2_05.linux.tgz
j2sdk1.4.2_05.linuxAMD64.tgz
Mark Brandon
foret37 is offline   Reply With Quote
Old   October 19, 2007, 04:26
Default Yes indeed, we are distributin
henry is on a distinguished road
Yes indeed, we are distributing the 32bit version of Java for 64bit machines because the 64bit version is unavailable. All of the machines at OpenCFD are now 64bit and this mix does not appear to be causing any problems here.
henry is offline   Reply With Quote
New version fluent file open in Old version ? MANOJKUMAR FLUENT 2 July 10, 2013 05:43
JAVA and an exersise Alej Main CFD Forum 1 July 17, 2006 10:25
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 05:18
Another Java error drungarius OpenFOAM Pre-Processing 1 October 6, 2005 20:31
java vs c++ zxaar Main CFD Forum 10 December 3, 2004 03:05
