Not able to copy the text file from one machine to another machine drive using Cgi script |
October 19, 2007, 08:37 |
Hi all,
Can any one give
Hi all,
Can any one give me the solution for this issue. I written a bat file called 'build.bat'.Its having following content. copy "DCP for MC1000c50cp v1.00.01.txt" "I:\Custom" The build.bat is calling inside the cgi script. If i run the cgi script through web, the copying is not happened. Whereas its copied if i run the build.bat file in command prompt. Regards, Selvam |
October 19, 2007, 08:55 |
I fail to see what this has to
Mark Olesen
Rep Power: 40 |
I fail to see what this has to do with OpenFOAM or with CFD. Please do not misuse the forum.
October 22, 2007, 06:44 |
@"I fail to see ...": Well, th
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
@"I fail to see ...": Well, this forum is driven by a CGI-script, so everyone here should have fundamental knowledge about security restrictions for CGIs on a Windows-Web-Server. Otherwise using this Forum would be careless.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
rotary machine | behzad bashiri | CFX | 2 | July 17, 2012 04:23 |
64 Bit machine | P | FLUENT | 7 | June 24, 2005 13:17 |
UDF problem in 2 CPU machine | David | FLUENT | 2 | April 18, 2004 09:02 |
can i install 5.5 and 4.3 in the same machine? | sword | CFX | 1 | April 2, 2002 09:45 |
Vector Machine? ??? | Abhijit Tilak | Main CFD Forum | 1 | May 21, 2001 19:13 |
