Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Problem in fvschemes divSchemes cannot use Gauss linearUpwind
Like Tree21Likes
Old   November 16, 2011, 04:02
Felipe
fippo_dk is on a distinguished road
how do your results compare to measurements? are you under or over predicting?
In my case I over predict from 10 to 20 degrees
fippo_dk is offline   Reply With Quote
Old   August 2, 2012, 15:34
uli
uli is on a distinguished road
hi all
I noticed that both in both tutorial cases and posted fvschemes there is always
div(R) Gauss linear;
Is that because there is no flux (phi = rho U) in that term and should it be left like this?
I tried
div(R)          Gauss limitedLinear 1;
div(R)          Gauss QUICK;
div(R)          Gauss MUSCL;
and it gave me similar results without any problems/errors.
thanks
Uli
uli is offline   Reply With Quote
Old   August 2, 2012, 15:40
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi! It is for other turbulence model where you use Reynolds stress
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   August 2, 2012, 16:12
uli
Thanks for your reply.
So using a k-Epsilon model does not involve R? But how is it possible that I get different results after switching the scheme for div(R)?
Old   August 2, 2012, 16:18
You wrote you get the SAME results. You can easily check which schemes you solver uses, just set "default none;", and you will get errors until you define all schemes.
Best regards,
Old   August 21, 2012, 19:34
uli
hi, sorry for the late reply.
I wrote "similar" results since the plots are slightly different. I removed the schemes and it still worked, thanks for your help.
Old   April 9, 2014, 02:54
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
Hi all,
I have to simulate the case of time varying BC 'uniformValue' for p and T
I tried various ways listed here and also from other open-sources, for schemes and solvers, to solve the 'p' with rhoSimpleFoam.
whatever may be the conditions applied, the solver is unable to run after third time-step. here I am posting my schemes and solvers. I am thinking that the problem is with these files only because I have cross-checked the p, T and U files and am also able to run 'rhoPimpleFoam' successfully.
Please let me know what went wrong.
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         cellLimited leastSquares 1;//Gauss linear;
//    grad(U)         Gauss linear;
    grad(P)         Gauss linear;
divSchemes
    default         none;//Gauss linear corrected; //
    div(phi,U)      bounded Gauss upwind;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
    div(phi,e)      bounded Gauss upwind;
    div(phi,h)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(phi,omega)   bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,K)      bounded Gauss upwind;
    div(phi,Ekp)    bounded Gauss upwind;
    div(phid,p)     Gauss upwind;//bounded Gauss upwind;
    div(U,p)      bounded Gauss upwind;
laplacianSchemes
    default         Gauss linear orthogonal;//Gauss linear corrected;
//    laplacian(muEff,U) Gauss linear corrected;
//    laplacian(alphaEff,e) Gauss linear corrected;
//    laplacian(alphaEff,h) Gauss linear corrected;
//    laplacian((rho*(1|A(U))),p) Gauss linear corrected;
//    laplacian((rho|A(U)),p) Gauss linear corrected;
//    laplacian((rho*rAU),p) Gauss linear corrected;
//    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
//   laplacian(DomegaEff,omega) Gauss linear corrected;
//    laplacian(DkEff,k) Gauss linear corrected;
//   laplacian(1,p) Gauss linear corrected;
interpolationSchemes
    default         linear;
    div(U,p)        upwind phi;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver         PCG;//GAMG;//
        preconditioner  none;//DIC;//FDIC;//GAMG;//diagonal;//
        agglomerator    faceAreaPair;
       tolerance       1e-07;
        relTol          0;//0.05;
        smoother        GaussSeidel;
        cacheAgglomeration true;//off;
        nCellsInCoarsestLevel 10;//20;
        mergeLevels     1;
    } //temperoraily not using
    "(U|e|h|R|k|epsilon|omega)" //"(U|p|e|h|R|k|epsilon|omega)"
        solver          smoothSolver;//solver          diagonal;//
        nSweeps         2;
        tolerance       1e-06;
//        relTol          0; //0.1;
//        solver          PBiCG;
//        preconditioner  DILU;
//        tolerance       1e-06;
//        relTol          0; //0.1;
//    "(k|epsilon|omega)"
//        $U;
//        tolerance       1e-05;
//        relTol          0; //0.1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    rhoMin          rhoMin [ 1 -3 0 0 0 ] 0.4;
    rhoMax          rhoMax [ 1 -3 0 0 0 ] 1.5;
   residualControl
        p               1e-2;
        U               1e-4;
        e               1e-3;
        // possibly check turbulence fields
        "(k|epsilon|omega)" 1e-3;
    }                       // residual control temporarily not used
PIMPLE
    momentumPredictor yes;
    nOuterCorrectors  1;
    nCorrectors       1;
    rhoMin            rhoMin [ 1 -3 0 0 0 ] 0.5;
    rhoMax            rhoMax [ 1 -3 0 0 0 ] 2.0;
    maxCo             0.2;
    rDeltaTSmoothingCoeff 0.1;
    rDeltaTDampingCoeff 1;
    maxDeltaT         1;
relaxationFactors
    fields
        p               0.03;
        rho             0.05;
    equations
        U               0.07;
        "(k|epsilon|omega)"   0.04;
        e               0.05;
        h               0.01;
adarsh tiwari is offline   Reply With Quote
Old   June 3, 2014, 06:29
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by adarsh tiwari View Post
Hi all,
relaxationFactors
fields
p 0.03;
rho 0.05;
equations
U 0.07;
e 0.05;
h 0.01;
// ************************************************** *********************** //[/CODE]
Is it a serious issue (bug)?
A user can edit those files.
Use the following conditions for relaxation factors:
relaxationFactors
fields
p 0.3;
rho 1;
equations
U 0.7;
"(k|epsilon|omega)" 0.7;
e 0.7;
h 0.7;
User has an option to edit the "fvSchemes" as well depending on problem statement.
Best Luck!
Tushar@cfd is offline   Reply With Quote
Old   August 9, 2018, 07:52
Sunil
sunilkonatham is on a distinguished road
Originally Posted by makaveli_lcf View Post
Hi!
gradSchemes
divSchemes
    default        none;
    div(phi,epsilon) Gauss linearUpwind grad(epsilon);  // OF20x syntax
    div(phi,k)       Gauss linearUpwind grad(k);  // OF20x syntax
    div(phi,U)       Gauss linearUpwind grad(U);  // OF20x syntax
    div((nuEff*dev(T(grad(U)))))     Gauss linear;  // OF20x syntax
My example which I use with pimpleFoam.
It has been a while since this thread is posted, can anyone please answer my question?
In this case, does it mean that divergence scheme Gauss linearUpwind uses the gradient scheme of respective variables?
Thanks,
Sunil.
sunilkonatham is offline   Reply With Quote
Old   August 9, 2018, 08:23
Thanks,
Sunil.
Yes, you are right. It can either use specific scheme listed in the gradient section or just use default scheme. You can also specify your name for the scheme to use it with several variables, for example like this:
gradSchemes
   default      none;
   grad(DDD)    cellLimited Gauss linear 1;
   grad(p)      leastSquares;
divSchemes
    default        none;
    div(phi,epsilon) Gauss linearUpwind grad(DDD);
    div(phi,k)       Gauss linearUpwind grad(DDD);
    div(phi,U)       Gauss linearUpwind grad(DDD);
lukasf likes this.
Best regards,
Old   August 9, 2018, 08:39
Sunil
Great. Thanks a lot Dr. Vakhrushev.
DivSchemes Gauss limitedLinearV and interfaceCompression nicasch OpenFOAM Running, Solving & CFD 1 July 12, 2010 11:26
FvSchemes sega OpenFOAM Running, Solving & CFD 2 February 15, 2010 12:07
DivSchemes limitedLinearV and interfaceCompression nicasch OpenFOAM 0 February 28, 2008 11:33
Divschemes limitedLinearV 1 and interfaceCompression nicasch OpenFOAM 0 February 27, 2008 13:24
FvSchemes from 12 to 11 fedegavo OpenFOAM Running, Solving & CFD 1 January 20, 2006 14:49
