BuoyantFoam and total pressure bc problem is a bug |
Rosario Russo
Rep Power: 17 ![]() |
Can anybody just comment this please?
http://www.cfd-online.com/cgi-bin/Op...9416#POST19416 Thanks. Rosario. |
Rosario Russo
I'm writing here a short summary and an update of the issue. I discovered that using totalPressure bc in buoyantFoam solver is not possible. The problem is that when pd is constructed via volScalarField pd ( IOobject ( "pd", runTime.timeName(), mesh ), p - rho*gh - pRef, p.boundaryField().types() ); the boundaryField types are not completely copied from p: i.e. the name for U phi and gamma are set to "undefined" and so the bc is made unusable. I have seen that this is due the a precise constructor of totalPressureFvPatchScalarField.C, so I think there must be a reason why Devolopers did so. By the way I realized that using this bc in buoyantFoam, choosing the isentropic relation to relate p and p0, would be misleading since the bc is used for the pd field which actually is a relative pressure: the isentropic relation would be wrong in this case. I'm not sure whether I'm right or whether I misunderstood something: any comments to sustain or deny what I said would be much appreciated. Thanks. Rosario. |
Rep Power: 22 ![]() |
The easiest way around such initialization problems is to change the constructor to pd to a "read" constructor which would then allow you to specify all the information necessary for totalPressure and other complex BCs and then set the initial field values to p - rho*gh - pRef using an assignment statement. Also to apply a totalPressure BC to pd you will need to take into account the fact that it is pd rather than p in the formulation of the BC.
Henry |
Rosario Russo
Ok. It is more or less what I did.
Thank you very much. Rosario. |
Total pressure problem | tangd | OpenFOAM Running, Solving & CFD | 7 | June 2, 2009 17:01 |
BuoyantFoam problem | miquelvinya | OpenFOAM Running, Solving & CFD | 25 | November 14, 2008 05:52 |
total pressure problem | Ermanno | CFX | 5 | February 19, 2007 17:16 |
total pressure in CFX | Atit Koonsrisuk | CFX | 0 | January 1, 2005 05:46 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
