May 23, 2008, 02:10 |
somebody know about thi
#41 |
Tian
Rep Power: 17 |
somebody know about this error? Thanks. Processing tag:2467 Starting reading patches at line 37237. For facegroup 0 named Walls trying to read 1442 patch face indices. --> FOAM FATAL ERROR : When reading patches expect Entity Type Code 8 At line 37240 From function readPatches in file ideasUnvToFoam.C at line 464. FOAM exiting
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance. |
July 2, 2009, 09:37 |
Throubles in ideasCsToFoam
#42 |
Délio Barroso de Souza
Rep Power: 17 |
I'm using OpenFOAM 1.4.1 and I have any problems with ideasCsToFoam. I can not export meshes generated in Salome to OpenFOAM. When I do it using this comand: ~/OpenFOAM/delio-1.4.1/run$ ideasUnvCSToFoam . icoPlaca /home/delio/salome_3.2.6/SAMPLES_SRC_3.2.6/Unv/PlacaOrificio.unv The following message appear to me: Exec : ideasUnvCSToFoam . icoPlaca /home/delio/salome_3.2.6/SAMPLES_SRC_3.2.6/Unv/PlacaOrificio.unv Date : Jul 02 2009 Time : 09:21:15 Host : nucop01-desktop PID : 23882 Root : /home/delio/OpenFOAM/delio-1.4.1/run Case : icoPlaca Nprocs : 1 Create time Processing tag:2411 Starting reading points at line 3. Read 186683 points. Processing tag:2412 Starting reading cells at line 373372. skipping cell (unknown type22) at line 373374 --> FOAM FATAL IO ERROR : Attempt to get back from bad stream file: IStringStream.sourceFile at line 0. From function void Istream::getBack(token& t) in file db/IOstreams/IOstreams/Istream.C at line 44. FOAM exiting I can't to resolve this and any suggestions to remedy this problem are welcome. Now, thanks for attention
November 13, 2009, 08:59 |
ICEM to OpenFOAM
#43 |
GRD
Rep Power: 17 |
I'm trying to convert a refined mesh from ICEM to openfoam. The only formats that support this kind of mesh is ideas or cfx5. As cfx5 cannot be converted to openfoam then IDEAS should be the path to follow. I'm able to convert the internal mesh but ideasUnvToFoam fails to read the patches. I'm afraid it could be something related with the 7 index at the beginning of the lines. I post part of the .unv file: INLET 7 2 0 0 7 4 0 0 7 6 0 0 7 8 0 0 7 10 0 0 7 12 0 0 7 14 0 0 7 16 0 0 7 18 0 0 7 20 0 0 7 22 0 0 7 24 0 0 7 26 0 0 7 28 0 0 7 30 0 0 7 32 0 0 Any help would be greatly appreciated. |
[Salome] Ideasunvtofoam and FoamX | micpage18 | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2007 11:17 |
