Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug or a feature of OF15
Old   July 18, 2008, 08:04
Default Description: After changing t
rafal zietara
rafal is on a distinguished road
Description:
After changing the writeInterval while
case is running OF doesnt write to
disk anymore.
Solver/Application:
bubbleFoam
Source file:
Testcase:
axiCase.tar.bz2
Platform:
probably non-specific but I run Gentoo 32
Version:
OpenFOAM 1.5
rebuilt
Notes:
I run the case as it is (attached).
after some time 0.4
I realised that
writeInterval 0.01;
in another terminal i changed
writeInterval 0.1;
and the cases are not written any more.
reverting back to
writeInterval 0.01;
and everything is like it was
(writing every 0.01s)
I run this case twice - the same result.
Thanks in advance
rafal is offline   Reply With Quote
Old   July 18, 2008, 08:24
Default I've had similar problems with
Juho Peltola
juho is on a distinguished road
I've had similar problems with the twoPhaseEulerFoam - a close relative to the bubbleFoam - in the 1.4.1 version. So it probably isn't a 1.5 related issue. Probably has more to do with the solver.
juho is offline   Reply With Quote
Old   July 19, 2008, 15:29
Default This is a known problem that o
henry is on a distinguished road
This is a known problem that occurs sometimes but not always when the writeInterval is changed. We will work on it when we have sorted some other pressing issues.
Henry
henry is offline   Reply With Quote
Old   July 25, 2008, 05:39
Default Could you try this fix and let
Mattijs Janssens
mattijs is on a distinguished road
Could you try this fix and let us know if it helps? (replace OpenFOAM/db/Time/TimeIO.C with attached version and 'wmake libso OpenFOAM')
TimeIO.C
mattijs is offline   Reply With Quote
Old   July 25, 2008, 06:18
Default Thanks for this. It works fine
rafal zietara
Thanks for this. It works fine now.
I was not really bothered so much by this bug.
It was more like making OF bulletproof.
Another not bothering bug is when in your
path or case have a space (for some strange
reason) ie
/home/OFuser/All cases/case1
with current implementation, the solver interprets it as two arguments. Again not bothering but worth to think for next release.
Cheers
Rafal
Old   July 25, 2008, 06:25
Default It would be VERY difficult to
It would be VERY difficult to support spaces in the "fileName" and "word" types in the OpenFOAM parser and we do not currently have any plans to attempt it. Have you considered using "_" instead of spaces in your file and directory names?
H
CoupledFvScalarMatrix in OF15 fisher OpenFOAM Running, Solving & CFD 9 May 27, 2020 10:40
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 11:54
Fan type BC in OF15 hsieh OpenFOAM Running, Solving & CFD 31 July 30, 2015 13:22
Bug in patchIntegrateC OF15 anger OpenFOAM Bugs 8 May 29, 2009 05:36
New feature article Jonas Larsson CFD-Wiki 2 December 14, 2005 09:10
