Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Rather obscure division by zero in triangleFuncsintersectAxesBundle
Old   August 12, 2008, 08:42
Default Version: OF-1.5 Description
Assistant Moderator
Bernhard Gschaider
Version: OF-1.5
Description: While reading in a STL into snappyHex it crashes with a division by zero in line 142 of meshTools/triSurface/triangleFuncs/triangleFuncs.C
The cause seems to be these parameters for intersectAxesBundle
V0-31.71428 0 -15.10714) V10-1.285715 8.99165e-16 -1.142858) V200 0 -1.678573) i0:0
For these parameters the local variable det = 8.9e-16*1.67 > SMALL (not by much ;) ) but u1=8.99e-16<SMALL and the routine then tries to divide by u2=0
I know it is a one in a million chance that this might happen, but it happened. I propose the following patch that tightens the restriction on det (and fixes this):
triangleFuncs.patch
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 12, 2008, 19:01
Default Thanks - I put it in. Does the
Mattijs Janssens
mattijs is on a distinguished road
Thanks - I put it in. Does the mag(u1)<SMALL need some non-dimensionalisation as well?
mattijs is offline   Reply With Quote
Old   August 13, 2008, 08:08
Default It might be good for consisten
Assistant Moderator
Bernhard Gschaider
It might be good for consistency but is in my experience not necessary.
Bernhard
About flow division sunnysun OpenFOAM Running, Solving & CFD 5 March 2, 2009 13:34
Division by zero vitke OpenFOAM Running, Solving & CFD 5 September 1, 2008 06:35
Division by zero in Xoodles hannes OpenFOAM Bugs 3 August 4, 2008 12:04
ScalarField division maka OpenFOAM Pre-Processing 2 August 27, 2007 06:10
