Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Proposal for an extension for the timeoptions of Utilities
Old   March 14, 2008, 10:37
Default Hi! One problem I encounter
Assistant Moderator
Bernhard Gschaider
Hi!
One problem I encounter frequently is that the options -time/-latestTime only let me specify either all or one time-step. This is sometimes quite inconvenient (for instance a reconstructPar of a case of which one half has already been reconstructed only gives me the possibility to reconstruct the first half of the timesteps anew or reconstruct one time-step at a time; for utilities like sample that remove old data when being called this is also quite annoying if you want to sample only two time-steps out of 100)
I thought it would be nice to have an option -times that gives the possibility to specifie multiple times:
-times 100,101.5,105
or specify a range
-times 100_110
or an open range
-times 100_
or only ever 2 seconds
-times 100_2_110
or only every 5th time-step in the range
-times 100:5:110
or a combination
-times 0,50,100_
What do you think?
Actually I did an example implementation. It's a bit clumsy because I tried not to modify the application-sources and did not want to modify kernel-classes, but it works alright and as far as I can tell it does not break compatibility with the old options. I'll append it as a patch.
timesOption.patch
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 14, 2008, 10:59
Default Yes I totally agree and a more
henry is on a distinguished road
Yes I totally agree and a more general time and time-range selection scheme has already been implemented which will be in included in the next release.
Henry
henry is offline   Reply With Quote
Old   August 20, 2008, 10:23
Default Excuse me for being a bit slow
Assistant Moderator
Bernhard Gschaider
Excuse me for being a bit slow-witted. That would be what the point "Extended time command line options." in the 1.5 Release-Notes is referring to, wouldn't it? My problem is, that I can't see how to select such a thing with the stock utilities (reconstructPar/checkMesh), I didn't find any reference in the documentation and in the source ($FOAM_SRC/OpenFOAM/include/addTime*.H etc would be the place to look at, wouldn't it?).
Did I miss something or is it possible that that feature got stuck in git somewhere and simply isn't in the release?
Bernhard
Old   August 21, 2008, 13:09
Default Hi Bernhard, I'm not at my
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Hi Bernhard,
I'm not at my desk at the moment, but take a look at the timeSelector class (I think), it is used in some of the utils like Mach etc.
olesen is offline   Reply With Quote
Old   August 25, 2008, 17:28
Default Hi Mark! Thanks. Didn't see
Assistant Moderator
Bernhard Gschaider
Hi Mark!
Thanks. Didn't see that.
As a repentance I wrote this little page on the Wiki for all those who don't want to look it up in the source:
http://openfoamwiki.net/index.php/Ti...ection_Options
Bernhard
Old   August 26, 2008, 20:13
Default Thanks for those tips Bernhard
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Thanks for those tips Bernhard :-)
msrinath80 is offline   Reply With Quote
Proposal for a modification of the initscripts to make switching versions easier gschaider OpenFOAM Bugs 2 December 21, 2007 15:10
New Utilities coops OpenFOAM Post-Processing 1 July 4, 2007 05:21
find a Phd and a master degree proposal Sabbagh Main CFD Forum 1 January 7, 2007 01:49
Proposal w.r.t. Meshing & Mesh Generation articles jasond CFD-Wiki 3 October 18, 2006 20:03
Reference Format Guidelines - a Proposal Jonas Larsson CFD-Wiki 4 September 16, 2005 05:54
