Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
FoamToVTK surfaceFields generates invalid files for 2D case
Old   September 2, 2008, 03:57
Default Description: When I try to r
Takuya OSHIMA
7islands is on a distinguished road
Description:
When I try to read surfaceFields_*.vtk files generated by foamToVTK -surfaceFields for 2D cases by ParaView it always fails with
Generic Warning: In /Volumes/RAID0data/paraview/ParaView3/VTK/IO/vtkDataReader.cxx, line 1363
Error reading binary data!
Solver/Application:
foamToVTK
Source file:
writeSurfFields.C
Testcase:
icoFoam/cavity or whatever
Version:
1.5
Notes:
Changing line 103 of writeSurfFields.C from
if (isA<emptyfvpatchvectorfield>(pf))
to
if (isA<emptyfvspatchvectorfield>(pf))
fixed the problem.
Regards,
Takuya
7islands is offline   Reply With Quote
Old   September 2, 2008, 04:43
Default Thanks - I put it in.
Mattijs Janssens
mattijs is on a distinguished road
mattijs is offline   Reply With Quote
Old   September 2, 2008, 09:12
Default Hi Mattijs, happened to pul
Niklas Wikstrom
wikstrom is on a distinguished road
Hi Mattijs,
happened to pull the latest git just now, and foamToVTK does not compile.
The change on line 103 in writeSurfaceFields.C
probably requires #include "emptyFvsPatchFields.H"
best regards
Niklas
wikstrom is offline   Reply With Quote
Old   September 2, 2008, 10:04
Default Thanks. Should be ok now.
Mattijs Janssens
Help on case and solution files download John Yang FLUENT 1 December 4, 2007 12:20
Different case files activate ALE Eq. kevin FLUENT 0 November 2, 2006 14:39
Where case files are written ereiss FLUENT 3 July 9, 2004 03:24
Pb with writing the Case and Dat files Sam FLUENT 2 May 14, 2004 12:16
Are Case and Data files enough? Zhengcai Ye FLUENT 6 January 8, 2004 05:02
