September 9, 2008, 09:35 |
Among other things, the
Ola Widlund
Rep Power: 17 |
Among other things, the collapseEdges utility removes faces with area < areaFactor * maxFaceArea, where maxFaceArea is the area of the largest face of the model, and areaFactor is hard-coded to 1e-9. I happen to run cases where there is a very large difference in size between smallest and largest cells. When working with 2D wedge geometries, I need collapseEdges to clean up after Bernhard's excellent makeAxialMesh utility. In some cases the hard-coded value for areaFactor is to large, and thousands of perfectly healthy faces are marked for removal... I here humbly contribute a modified version, collapseEdgesBetter, in which the option -areaFactor can be used to set a sound value. If missing, the hard-coded value 1e-9 is used as default. Best regards, Ola collapseEdgesBetter.ZIP |
[mesh manipulation] CollapseEdges after makeAxialMesh utility in subversion testcase | bonzodeb | OpenFOAM Meshing & Mesh Conversion | 1 | June 5, 2009 04:24 |
modification of UDF | ammi | FLUENT | 2 | January 18, 2007 22:35 |
KIVA Modification | Gede | Main CFD Forum | 0 | May 10, 2006 23:06 |
modification for CFX? | caty | CFX | 5 | May 19, 2005 19:48 |
UDF modification | merac | FLUENT | 4 | March 1, 2001 07:42 |
