Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
TwoPhaseEulerFOAM application
Old   November 16, 2006, 08:25
Default Description: The application
Rasmus Hemph
hemph is on a distinguished road
Description:
The application gives erroneous solution for the Ua-field when the particle-particle force is included (g0 > 0). If settling particles are simulated, the velocity of the particles does not approach zero as they reach the bottom of the domain.
Solution. The ppMagf-term in alphaEqn.H: should be divided by alphaf on row 26.
Old:
ppMagf = g0*rUaAf*min(exp(preAlphaExp*(alphaf - alphaMax)), expMax);
New:
ppMagf = 1.0/(rhoa*max(alphaf,SMALL))*g0*rUaAf*min(exp(preAlpha Exp*(alphaf - alphaMax)), expMax);
Also row 32 in alphaEqn.H needs to be changed.
Old:
alphaEqn -= fvm::laplacian(ppMagf, alpha);
New:
alphaEqn -= fvm::laplacian(alphaf*ppMagf, alpha);
Solver/Application:
twoPhaseEulerFoam
Source file:
alphaEqn.H
Testcase:
Platform:
All
Version:
All
Notes:
The dimension of g0 is in Pascal in most references. In twoPhaseEulerFoam the dimensions of g0 is Pa/(kg/m3). To aid comparison between models, the ppMagf term should be divided by rho, as
with a corresonding change to the dimensions of g0 in constant/ppProperties
hemph is offline   Reply With Quote
Old   November 16, 2006, 08:33
Default Not a bug, they were left out
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
Not a bug, they were left out deliberately.
ppMagf is only important around and below alphaMax and the g0 constant can be modified to account for the division/multiplication of alpha.
Niklas
niklas is offline   Reply With Quote
Old   November 16, 2006, 13:09
Default Sorry, but why is this term le
Rasmus Hemph
Sorry, but why is this term left out? According to the equations they should be there. With the proposed fix included I get expected results. Without it, physics are wrong and results suspicious. Try the supplied test case for an example. I also disagree about ppMagf. It is certainly important over a wide range of volume fractions in packing of for instance a soft material.
//Rasmus
Old   November 16, 2006, 14:18
Default To expand the discussion. Alth
Rasmus Hemph
To expand the discussion. Although you could exclude the division of alpha in the ppMagf-calculation (for hard materials), the "bug", I believe, is in the laplacian-term. There ppMagf needs to be multiplied by alpha to give correct results.
Old   November 22, 2006, 16:45
Default Does the term in pEqn.H stay u
Alberto Passalacqua
Does the term in pEqn.H stay unchanged?
Regards,
Alberto
Alberto Passalacqua
Old   January 19, 2007, 08:01
Default Sorry, missed your message Alb
Rasmus Hemph
Sorry, missed your message Alberto. I believe that pEqn.H remains unchanged. The change in the code applies to the ppMagf-term, which is calculated in alphaEqn.H.
Old   January 19, 2007, 08:43
Default OK. Thanks for your confirmati
Alberto Passalacqua
OK. Thanks for your confirmation. :-)
Alberto Passalacqua
Old   May 26, 2008, 04:12
Default It seems to me the equations t
Juho Peltola
juho is on a distinguished road
It seems to me the equations that Rasmus reports as erroneous are still used in the twoPhaseEulerFoam in the 1.4.1 release.
Has there been chenges to the solver after the bug report? Is the bug report still valid?
juho is offline   Reply With Quote
Old   May 26, 2008, 06:59
Default Are we all agreed that the pro
henry is on a distinguished road
Are we all agreed that the proposed change is correct? If so I will put it in 1.5. Do we have a reference or derivation which covers this?
Henry
henry is offline   Reply With Quote
Old   May 27, 2008, 00:09
Default Expressions for the solids nor
Alberto Passalacqua
Expressions for the solids normal stress modulus are empirical. You can find a summary and a list of references here
http://www.scielo.br/scielo.php?script=sci_arttext&pid=S0100-73862001000200006&l ng=&nrm=iso&tlng=#tab01
together with a short explanation of how they're used inside the particle phase momentum equation.
I have almost all the original references, if necessary.
Alberto
Alberto Passalacqua
Old   May 27, 2008, 04:04
Default From these do you agree with R
  #11
From these do you agree with Rasmus' change?
Henry
Old   May 27, 2008, 08:26
Default Which change is under discussi
  #12
Rasmus Hemph
Which change is under discussion here?
I have reported five different issues. I do not have the 1.41 source heres, so I can not tell which ones have been corrected.
First, there is a missing alpha in the laplacian-expression of the alphaEqn. The inclusion of alpha can be shown from the equations and was found to be important to the physics.
Second, ppMagf should be divided by alpha*rho. Niklas left this out and left it to the user to modify the expression for G. However, for soft materials, there is a particle-particle force over a wide range of volume fractions, which falsifies the assumption of alpha at packing being a constant. (Also, as alpha has no dimensions, the user would need to read through the source code to understand that she needed to multiply her constant by alpha..)
Thirdly, there is (was?) a grave bug in the interpolation of particle-particle forces to the faces. It has been reported here http://www.cfd-online.com/OpenFOAM_D...tml?1173086743
Fourthly, there is a problem with certain boundary conditions for particles. It was reported here http://www.cfd-online.com/OpenFOAM_D...tml?1170065229
Rasmus
Old   May 27, 2008, 08:50
Default Hi Rasmus, I assumed that i
  #13
Hi Rasmus,
I assumed that it was the change at the top of this list being discussed. I am happy to include any changes you think appropriate but as I am not currently developing or running this solver I can't test or verify it. If you could send me the latest code I would be happy to merge it into the 1.5 release if you would like me to.
Thanks
Henry
Old   May 27, 2008, 08:51
Default As far as I can see at least i
  #14
Juho Peltola
As far as I can see at least issues 1-3 exist in the 1.4.1.
Old   May 27, 2008, 10:00
Default Hi Henry and Juho, I think tha
  #15
Rasmus Hemph
Hi Henry and Juho, I think that it would be good if the changes came into 1.5. They have been found to increase stability quite a lot. The code I have been running is largely modified for a possible article and is hard to submit for inclusion as is.
However, here is a suggestion of a fix for the bug in interpolation (third bug in my post) and particle forces calculation (first and second). The changes needs to go into alphaEqn.H. Warning, I do not have access to a linux computer at the moment, so there is possibly some syntatic errors. Note that the dimensions of g0 need to change in the tutorial test case as well. I would be very happy if someone was willing to test it on the tutorials.
Old code:
if (g0.value() > 0.0)
surfaceScalarField alphaf = fvc::interpolate(alpha);
// Correct the particle-particle force magnitude
New code:
volScalarField G = (1.0/(rhoa*(alpha+scalar(0.0001))))*g0*min(exp(preAlpha Exp*(alpha - alphaMax)), expMax));
ppMagf = rUaAf*fvc::interpolate(G);
alphaEqn -= fvm::laplacian(((alphaf+scalar(0.0001))*ppMagf), alpha);
Rasmus
Old   May 27, 2008, 10:17
Default Thank you. It compiled fine. R
  #16
Juho Peltola
Thank you. It compiled fine. Requires an ugly entry to fvScemes.
I can run tests on the tutorials. At least it seems to run fine on another test case I have.
Old   May 27, 2008, 10:55
Default Good. Thanks for trying it out
  #17
Rasmus Hemph
Good. Thanks for trying it out. To get rid of the ugly entry, I believe you can give the term a name, which is then called in fvSchemes. In Ueqn.H for example, it is fvm::div(phia, Ua, "div(phia,Ua)").
Old   May 27, 2008, 11:26
Default Is there a reason not to use
  #18
Juho Peltola
max(alphaf,SMALL)
max(alpha,SMALL)
instead of
The latter seems a lot less stable.
Old   May 27, 2008, 12:09
Default False alarm. The instability w
  #19
Juho Peltola
False alarm. The instability wasn't related to the max(alphaf,SMALL) vs. (alphaf+scalar(0.0001)).
But is there a reason to choose on over the other?
Does max() compare and replace values of each cell in of any field?
A difference between the approaches is of course that the max() filters out even negative values of magnitude larger than 0.0001 and for debugging reasons it migth be nice that such values cause an error.
Old   May 27, 2008, 15:32
Default The reason for going with 0.00
  #20
Rasmus Hemph
The reason for going with 0.0001 here was an attempt to make the division a little better numerically, as SMALL is 1e-15. The same term is multiplied in the laplacian equation later. I do not know if it made any practical difference, but I agree that is a bit ugly with a free scalar like that.
If I recall correctly, you can not do max(alphaf, SMALL) unless both terms are of the same dimension (because of the replacement), so you need to create a new dimensioned scalar, but principally it should be ok.
TwoPhaseEulerFoam sara OpenFOAM Running, Solving & CFD 2 November 6, 2008 20:26
Bug in twoPhaseEulerFoam alberto OpenFOAM Bugs 2 May 20, 2008 22:25
TwoPhaseEulerFoam Bug alondono OpenFOAM Bugs 1 February 19, 2008 21:01
TwoPhaseEulerFOAM application hemph OpenFOAM Bugs 0 November 16, 2006 08:27
TwoPhaseEulerFoam newbee OpenFOAM 0 March 27, 2006 09:41
