Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Tutorial case lesCavitatingFoam
Old   September 24, 2008, 13:47
Default Problem - The default tutorial
Aditya Chunekar
achuneka is on a distinguished road
Problem - The default tutorial case (throttle3D) for lesCavitatingFoam blows up
Platform - Linux (Redhat version 4.2)
Negative pressure and hence very high values of U observed.
At time = 0.004, the code blows.
achuneka is offline   Reply With Quote
Old   September 25, 2008, 14:49
Default Thanks for the report. There i
Mattijs Janssens
mattijs is on a distinguished road
Thanks for the report. There is no immediate bug in the code. We've only run it up to 1e-4 so you are a bit in uncharted territory. The physics are quite complex so you might want to make the numerics a bit more stable.
- make sure you use the mapped solution from the 2D case to start.
- limit the gradients on the velocity if the turbulence quantities go unstable.
- change the div scheme to e.g. upwind.
mattijs is offline   Reply With Quote
Problem starting a tutorial case alank OpenFOAM Installation 1 December 12, 2006 17:50
case and dat file of FLUENT tutorial Sajad Ranjbaran FLUENT 0 November 8, 2006 07:55
Tutorial bCavityb case problem wells OpenFOAM Installation 2 March 21, 2005 08:55
Case in Fluent Tutorial 1 Lam FLUENT 0 August 24, 2004 12:25
XiFoam tutorial case pratap OpenFOAM Running, Solving & CFD 1 March 1, 2004 06:25
