Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC
Old   October 9, 2008, 05:19
Default Description: An improvement
Richard Kenny
richpaj is on a distinguished road
Description:
An improvement to the update of T_, psi_, mu_, and alpha_ (also Tu_)
in hMixtureThermo.C and hhuMixtureThermo.C.
"oldTime" information for the internalField values
of T_, psi_, mu_, and alpha_ (also Tu_) is apparently lost
For example, in the Euler scheme, fvc::ddt(T) = 0 for internalField
values (boundary values, however, differentiate correctly).
(I don't think using "T.storeOldTimes()" will help here, though I stand to be corrected).
Remedy:
in hMixtureThermo.C
from line 73
forAll(T_, celli)
const typename MixtureType::thermoType& mixture_ =
this->cellMixture(celli);
T_[celli] = mixture_.TH(h_[celli], T_[celli]);
psi_[celli] = mixture_.psi(p_[celli], T_[celli]);
mu_[celli] = mixture_.mu(T_[celli]);
alpha_[celli] = mixture_.alpha(T_[celli]);
Replace with
forAll(T_, celli)
T_.internalField()[celli] = mixture_.TH(h_[celli], T_[celli]);
psi_.internalField()[celli] = mixture_.psi(p_[celli], T_[celli]);
mu_.internalField()[celli] = mixture_.mu(T_[celli]);
alpha_.internalField()[celli] = mixture_.alpha(T_[celli]);
hhuMixtureThermo.C
from line 86
forAll(T_, celli)
Tu_.internalField()[celli] = this->cellReactants(celli).TH(hu_[celli], Tu_[celli]);
Replace with:
forAll(T_, celli)
psi_internalField()[celli] = mixture_.psi(p_[celli], T_[celli]);
mu_internalField()[celli] = mixture_.mu(T_[celli]);
alpha_internalField()[celli] = mixture_.alpha(T_[celli]);
Tu_internalField()[celli] = this->cellReactants(celli).TH(hu_[celli], Tu_[celli]);
richpaj is offline   Reply With Quote
Old   October 9, 2008, 06:29
Default Thanks very much for your bug
henry is on a distinguished road
Thanks very much for your bug report and proposed fix. Your solution will certainly work but has a run-time overhead and would stop the loops vectorizing. Using "T.storeOldTimes()" etc. before the loop would work and more efficiently (note that T.internalField() simply calls T.storeOldTimes() before returning the field). I will implement this change and upload it to our 1.5.x git repository.
H
henry is offline   Reply With Quote
Old   October 9, 2008, 23:14
Default That's useful to know about st
Richard Kenny
That's useful to know about storeOldTimes(), many thanks, RGK
SurfaceTransformPoints rotate suggestion for improvement markc OpenFOAM Pre-Processing 1 August 13, 2011 09:47
SurfaceTransformPoints rotate suggestion for improvement markc OpenFOAM Pre-Processing 0 January 9, 2009 03:28
Jet Impingement (results improvement) ... Sri FLUENT 6 July 16, 2007 07:33
Improvement in makeDeltaCoeffs rolando OpenFOAM Bugs 3 May 15, 2007 13:49
sponsership-research-innovative improvement-wind amit Main CFD Forum 0 February 9, 2006 08:51
