Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug in patchIntegrateC OF15
Old   September 24, 2008, 06:08
Default Hello, I noticed that patch
Thomas Wolfanger
anger is on a distinguished road
I noticed that patchIntegrate delivers the same area magnitude vector for any patch.
To calculate the area vector of the patch actually under consideration, change line 78 of patchIntegrate.C to read:
Info<< " Patch area = " << sumCmptMag(mesh.boundaryMesh()[patchi].faceAreas()) << endl;
which (at least for my testcase) delivers correct values.
Best regards,
-Thomas
anger is offline   Reply With Quote
Old   September 24, 2008, 06:31
Default Just a note on the above "fix"
Thomas Wolfanger
Just a note on the above "fix":
for patches which have "positive" and "negative" faceAreas, the outcome of this calculation is wrong.
If, for example, the frontal area of a wing is calculated, the result will be two times as large as the correct one because the wing surface is closed; not only the visible part is taken into account, but also the "invisible" part lying downstream of the point of largest profile thickness. Anyone knows how to calculate the "visible" part generally?
Best regards,
-Thomas
Old   September 24, 2008, 06:41
Default Thanks for the bug report. To
henry is on a distinguished road
Thanks for the bug report. To be consistent with the usage the patch area should be output as
Info<< " Patch area = " << sum(mesh.Sf().boundaryField()[patchi]) << endl;
I will push this fix into our git repository.
H
henry is offline   Reply With Quote
Old   October 27, 2008, 12:14
Default Hi, further, patchIntegrate
Niklas Wikstrom
wikstrom is on a distinguished road
further, patchIntegrate and patchAverage are not presently parallelised:
Solution: replacing sum with gSum in "integration" works nicely.
n.
wikstrom is offline   Reply With Quote
Old   October 27, 2008, 12:41
Default Good point, I will make this c
Good point, I will make this change
Thanks
H
Old   October 27, 2008, 13:14
Default Henry, you guys are doing a
Niklas Wikstrom
Henry,
you guys are doing a great job.
Thank you all!
n
Old   May 28, 2009, 13:06
David P. Schmidt
schmidt_d is on a distinguished road
Henry,
The gsum(mesh.Sf().boundaryField()[patchi]) adds up the surface normal vectors over the patch. May I suggest changing this to be magSf instead? The sum of the vectors is not really an area. What if you were integrating a quantity over a closed surface!?
Regards,
David
schmidt_d is offline   Reply With Quote
Old   May 29, 2009, 03:56
David,
> over the patch.
Correct
We could do this additionally.
It is an area, it is the directed area.
That is true, it may not be what you want in this case but in many cases it is what you want.
Henry.
Old   May 29, 2009, 05:36
I have pushed some enhancements to patchIntegrate to 1.5.x.
Henry
CoupledFvScalarMatrix in OF15 fisher OpenFOAM Running, Solving & CFD 9 May 27, 2020 10:40
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 11:54
Fan type BC in OF15 hsieh OpenFOAM Running, Solving & CFD 31 July 30, 2015 13:22
Is it a bug in Userbs Guide for OF15 kai OpenFOAM Bugs 1 October 2, 2008 09:07
Bug or a feature of OF15 rafal OpenFOAM Bugs 5 July 25, 2008 06:25
