Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
tensors cofactors
Old   November 11, 2008, 08:18
Default I noticed that expression a) w
Maka Mohu
maka is on a distinguished road
I noticed that expression a) works while b) and c) does not. I use V 1.3
volTensorField T = ...;
a) Foam::inv(T);
b) Foam::cof(T);
error: 'cof' was not declared in this scope.
c) Foam::cofactors(T);
error: no matching function for call to 'cofactors(Foam::volTensorField&)'
Thanks.
maka is offline   Reply With Quote
Old   November 11, 2008, 08:49
Default Currently (version 1.5) the "c
henry is on a distinguished road
Currently (version 1.5) the "cofactors" function is defined for:
SymmTensorI.H://- Return the cofactor tensor of a symmetric tensor
SymmTensorI.H:inline SymmTensor<cmpt> cofactors(const SymmTensor<cmpt>& st)
TensorI.H://- Return the cofactor tensor of a tensor
TensorI.H:inline Tensor<cmpt> cofactors(const Tensor<cmpt>& t)
if you think it would be useful to have this function available at the field level I will propagate it through.
H
henry is offline   Reply With Quote
Old   November 11, 2008, 11:31
Default I managed to get cofactors wit
Maka Mohu
I managed to get cofactors with an indirect way by:
volTensorField M ...;
Mcof=(inv(M)*det(M)).T();
but it is not efficient. I would be grateful if you could propagate such cof function to the field level (similar to inv) in both definitions. If you could post the modification relative to V1.5 I will try to manage from there. Many thanks for your help.
Best regards,
Maka.
Old   November 11, 2008, 12:09
Default Will do.... H
Will do....
H
Old   November 14, 2008, 14:46
Default ...done. I have also rename
...done.
I have also renamed "cofactors" "cof" for consistency with the rest of the 3-char tensor function names.
The updates are now in our 1.5.x git repository.
H
Old   November 17, 2008, 09:31
Default Thanks Henry.
Maka Mohu
Thanks Henry.
Tensor mathematics forAll macro combination tensors with vectors olesen OpenFOAM Running, Solving & CFD 4 February 25, 2009 06:03
tensors cofactors maka OpenFOAM Running, Solving & CFD 3 November 30, 2008 08:32
No matching function multiplying tensors for BC Erik OpenFOAM 3 March 20, 2008 14:05
Surface interpolation scheme with tensors as weighting factors jutta OpenFOAM Running, Solving & CFD 1 August 27, 2007 12:00
Surface interpolation of tensors andebjor OpenFOAM Pre-Processing 2 August 23, 2007 04:08
