Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
SnappyHexMesh plane surface bounding box
Old   August 21, 2009, 08:15
Mattijs Janssens
mattijs is on a distinguished road
This should work. Check that your locationInMesh is inside a cell and inside the part you want to keep. The minVol setting in meshQualityControls will not affect refinement. only snapping and layering.
mattijs is offline   Reply With Quote
Old   August 26, 2009, 07:13
andres
andresbh is on a distinguished road
Hi Mattijs,
thank you for your reply. I double checked that locationInMesh is inside the part I want to keep. I deployed snappyhexmesh again and I ran a simulation with the resulting mesh.
In the following figure you see a slide through the domain. Here the circular white lines represent the outer part of my stl body. Inside in red is what should have been removed. The speed in these red regions is zero with a wall-like behavior outside the withe lines which is feasable. I could live with this but the problem are those regions inside the circles with a non-zero velocity.
Have you got any experience with something like this?
I also attach my blockmeshdict and snappyhexmeshdict so that you can make yourself a better idea of my settings. I cant upload my stl file because it is quite large.
snappyHexMeshDict.txt
blockMeshDict.txt
Thank you again for your help
cheers
Andres
andresbh is offline   Reply With Quote
Old   August 26, 2009, 08:34
Mattijs Janssens
Looks like your stl isn't closed enough and the mesh has 'bled' through (the mesher does ray intersection tests to determine hits on the surface). Run surfaceCheck on your individual stls and check for edges with <>2 faces. Fix or perturb your stls and try again.
[snappyHexMesh] Surface boundary mesh in snappyHexMesh bastil OpenFOAM Meshing & Mesh Conversion 7 February 3, 2012 08:37
[CAD formats] Tool for Surface Preparation for SnappyHexMesh bastil OpenFOAM Meshing & Mesh Conversion 18 November 17, 2008 17:49
[Commercial meshers] Import Surface from HyperMesh to snappyHexMesh bastil OpenFOAM Meshing & Mesh Conversion 7 October 7, 2008 08:32
postprocessing - surface - plane Brujo FLUENT 2 March 1, 2008 11:36
Making boundary profile on a surface in xz- plane varghese FLUENT 6 May 3, 2002 09:38
