Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Segmentation Fault in fluent3DMeshToFoam
Old   December 3, 2008, 08:50
Default Hi, So this means I've got t
  #21
Wassja A. Kopp
wassja is on a distinguished road
So this means I've got to check out the files with git and compile them manually? This may be hard because my linux-system doesn't have a connection to the Internet.... I'd be glad if I could download a compiled 64bit version of this new fluent3DMeshToFoam so I can convert my porous zones from fluent to OF. Otherwise I could try to use the 1.4.1 version, but I'm quite happy with 1.5 and don't know if it's possible to use fluent3DMeshToFoam in version 1.4.1 and then run in 1.5.
Regards
Wassja
wassja is offline   Reply With Quote
Old   March 16, 2009, 03:59
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Originally Posted by mattijs View Post
Pushed a changed fluent3DMeshToFoam.L to the 1.5.x git which reads your file. Let me know if it breaks anything else ;-)
I met the same problem, and using the new fluent3DMeshToFoam.L works, Thanks
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   March 16, 2009, 04:28
Thumbs up 3D fluent mesh
  #23
ksr
sudhakar
ksr is on a distinguished road
Dear friend,
you can do the remeshing starting from lines, areasand then volume mesh. you will get the 3d mesh only after error free 2d mesh.Try again.
ksr is offline   Reply With Quote
Old   April 13, 2011, 16:37
Default ERROR sigsegv
  #24
Marta
martals is on a distinguished road
I am new in OpenFOAM and I´m trying to convert a 2d mesh (.msh) from Fluent to OpenFOAM usinf FluentMeshToFoam. (OF 1.7.1.)
I got the same error "SigSev" and also "Printstack".
It appears this message in OF:
hemodynamics@marioc-PowerEdge-R300:~/OpenFOAM/hemodynamics-1.7.1/run/marta/poiseuille_mesh$ fluentMeshToFoam ascii.msh
| \\ / O peration | Version: 1.7.x |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.x-3776603e4c6c
Exec : fluentMeshToFoam ascii.msh
Date : Apr 11 2011
Time : 22:45:41
Host : marioc-PowerEdge-R300
PID : 13356
Case : /home/hemodynamics/OpenFOAM/hemodynamics-1.7.1/run/marta/poiseuille_mesh
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
number of faces: 1643
Number of points: 203
Reading uniform faces
Reading points
FINISHED LEXING
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
in "/opt/openfoam171/applications/bin/linux64GccDPOpt/fluentMeshToFoam"
#4 __libc_start_main in "/lib/libc.so.6"
Violación de segmento
Does anybody now what this errors mean? I don´t know how to solve them! I would appreciate any help! Thanks in advance!!
martals is offline   Reply With Quote
Segmentation fault. Nari Siemens 3 November 8, 2007 06:04
segmentation fault Suman Siemens 2 June 26, 2007 04:14
Segmentation fault billy OpenFOAM Installation 20 April 23, 2007 23:57
Segmentation fault??? LiQiang Main CFD Forum 3 March 18, 2005 14:25
Segmentation fault Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 3 January 10, 2005 06:02
