Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bugs in polySplineEdgeC
Old   June 2, 2008, 03:03
Default 1) Description: Using polySp
kbr
Kerstin
kbr is on a distinguished road
1)
Description:
Using polySpline in blockMeshDict with interpolating points not in-line gives only a straight line between start and end point.
Old (OF 1.4.1, polySplineEdge.C, line 78):
scalar interval = (N-3)/N;
New:
scalar interval = (N - scalar(3))/N;
2)
Description:
Depending on the operating system it may occur a problem with "readLabel(is), readLabel(is)" reading the labels of the two vertices the spline connects because it is not specified which label is read first.
A suggestion that may help is to use another constructor of curvedEdge:
Old (OF 1.4.1, polySplineEdge.C, line 132):
curvedEdge(points,readLabel(is),readLabel(is));
New:
curvedEdge(points,is);
Kerstin
kbr is offline   Reply With Quote
Old   June 2, 2008, 06:56
Default Hi Kerstin, Thanks for the
henry is on a distinguished road
Hi Kerstin,
Thanks for the corrections, I will put them in 1.5
Henry
henry is offline   Reply With Quote
Old   June 6, 2008, 14:04
Default Hi Kerstin, thank you very
Franz
ffbof is on a distinguished road
Hi Kerstin,
thank you very much for that suggestion.
It helped, we are now totally happy.
It was a very good work to find that bug. How long have you searched for the solution ?
I tried which result i get for example:
label N = 12
label result = ( N-3 )/N
leads to N = 0;
But
label result = ( N-scalar(3) )/N
leads to N = 0.75
This is a strange thing, i thought a label is similar to an int.
So again thank you very much for your effort.
ffbof is offline   Reply With Quote
Bugs in fvcsurfaceIntegrate su_junwei OpenFOAM Bugs 4 July 7, 2013 11:29
Bugs in FFT luca OpenFOAM Bugs 2 January 27, 2009 16:40
Wiki - Bugs Andy R Main CFD Forum 0 July 25, 2008 14:15
bugs in starcd 4.06 whitemelon Siemens 0 July 11, 2008 07:26
starcd 3.24 has bugs? whitemelon Siemens 6 May 16, 2008 11:44
