Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Help PV3FoamReader compile error
Old   November 13, 2008, 00:33
Default Dear All, When compiling PV
Zhizhong Li
zzli is on a distinguished road
Dear All,
When compiling PV3FoamReader I got the following error:
CMake Error: Error in cmake code at
/home/hyp/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/Qt/Core:458:
Unknown CMake command "QT4_WRAP_CPP".
/home/hyp/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/P V3FoamReader/PV3FoamReader/CMakeLists.txt:44:
A command failed during the invocation of macro "ADD_PARAVIEW_GUI_EXTENSION".
/home/hyp/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc/Qt/Core:562:
ADD_PARAVIEW_GUI_EXTENSION unknown error.
Current CMake stack: /home/hyp/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/P V3FoamReader/PV3FoamReader/CMakeLists.txt;/home/hyp/OpenFOAM/ThirdParty/cmake-2. 4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCInformation.cmake;/home/hyp/Op enFOAM/ThirdParty/cmake-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCXXIn formation.cmake
A command failed during the invocation of macro "ADD_PARAVIEW_PLUGIN".
/home/hyp/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/P V3FoamReader/PV3FoamReader/CMakeLists.txt:43:
ADD_PARAVIEW_PLUGIN unknown error.
-- Configuring done
+ make
make: *** No targets specified and no makefile found. Stop.
Anybody can help? Thank you very much.
zzli is offline   Reply With Quote
Old   November 13, 2008, 05:21
Default Sounds as if you are using an
Mattijs Janssens
mattijs is on a distinguished road
Sounds as if you are using an old version of cmake. "cmake --version" returns for me
cmake version 2.4-patch 6
mattijs is offline   Reply With Quote
Old   November 13, 2008, 06:00
Default Yes cmake version is right 2.4
Zhizhong Li
Yes cmake version is right 2.4-patch 6. Thanks.
Old   November 19, 2008, 15:27
Default Hi, I receive the same erro
Ulrich Heck
ulli is on a distinguished road
I receive the same error message while compiling
1.5.X. on OpenSuse 10.3 64 bit.
I think qmake and cmake should be okay. Is it needed to build paraview new or to perform any changes in the ThirdParty directory when switching from 1.5 to 1.5.X?
'/home/ulli/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libvtkPV3Foam.so' is up
to date.
make[3]: Leaving directory `/home/ulli/OpenFOAM/OpenFOAM-1.5.x/applications/util
ities/postProcessing/graphics/PV3FoamReader/vtkPV3Foam'
+ cd PV3FoamReader
+ mkdir -p Make/linux64GccDPOpt
+ cd Make/linux64GccDPOpt
+ cmake ../..
-- Loading ParaView CMake commands
-- Loading ParaView CMake commands - done
#ifndef _@PLUGIN_NAME@Plugin_h:458:
/home/ulli/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphic
s/PV3FoamReader/PV3FoamReader/CMakeLists.txt:44:
#ifndef _@PLUGIN_NAME@Plugin_h:562:
OpenFOAM/OpenFOAM-1.5.x> qmake -v
QMake version 2.01a
Using Qt version 4.3.1 in /usr/local/Trolltech/Qt-4.3.1/lib
ulli@linux2:~/OpenFOAM/OpenFOAM-1.5.x>
cmake --version
Any ideas how to solve this problem?
Thanks in advance
Ulrich
ulli is offline   Reply With Quote
Old   November 26, 2008, 12:09
Default Dear all We followed the ins
sonia esteban
gmc_salta is on a distinguished road
Dear all
We followed the instructions for installation OF1.5, in SUSE10.3 for 32 bit. We install some packages suggest in other discussion(GCC, Cmake, mpfr, gmp, flex++, etc) also we done the symbolic link for library python, as root.
We revised the correct QT version
>qmake --version
QMake version 2.01a
Using Qt version 4.3.1 in /usr/lib
But in our Yast indicated that version Qt is Qt3.3.8-76. Is it correct?
When execute ./Allwmake followed message error we obtained:
make[3]: Leaving directory `/home/foam5/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/miscell aneous/engineCompRatio'
make[2]: Leaving directory `/home/foam5/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/miscell aneous'
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/foam5/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing'
make: *** [postProcessing] Error 2
make: Target `application' not remade because of errors.
+ '[' '' = doc ']'
When build paraView3.3-cvs (step 7-1, readme), this message error get:
Linking CXX executable ../../../../bin/HybridCxxTests
[ 28%] Built target HybridCxxTests
Scanning dependencies of target WidgetsCxxTests
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/WidgetsCxxTests.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/BoxWidget.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/TestContourWidget2.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/TestHandleWidget.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/TestImplicitPlaneWidget.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/TestOrientationMarkerWidg et.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/TerrainPolylineEditor.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/TestDijkstraGraphGeodesic Path.o
[ 28%] Building CXX object VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/TestParallelopipedWidget. o
Linking CXX executable ../../../../bin/WidgetsCxxTests
collect2: ld terminated with signal 11 [Segmentation fault]
make[2]: *** [bin/WidgetsCxxTests] Error 1
make[1]: *** [VTK/Widgets/Testing/Cxx/CMakeFiles/WidgetsCxxTests.dir/all] Error 2
make: *** [all] Error 2
done
So, if somebody got an idea about this error, pleased help us. Are missing another packages install for?
Ana and Sonia
gmc_salta is offline   Reply With Quote
Old   December 15, 2008, 06:32
Default Hi I installed openFOAM in F
Velan
velan is on a distinguished road
Hi
I installed openFOAM in FC8. I got the same error message which is posted above.
+ cmake ../..
================================================== ======================*/:458:
/home/vc/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV 3FoamReader/PV3FoamReader/CMakeLists.txt:44:
================================================== ======================*/:562:
Current CMake stack: /home/vc/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV 3FoamReader/PV3FoamReader/CMakeLists.txt;/home/vc/OpenFOAM/ThirdParty/cmake-2.4. 6/platforms/linux/share/cmake-2.4/Modules/CMakeCInformation.cmake;/home/vc/OpenF OAM/ThirdParty/cmake-2.4.6/platforms/linux/share/cmake-2.4/Modules/CMakeCXXInfor mation.cmake
/home/vc/OpenFOAM/OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV 3FoamReader/PV3FoamReader/CMakeLists.txt:43:
-- Configuring done
$ cmake --version
Can you please suggest me what need to be do ?
velan is offline   Reply With Quote
Old   December 16, 2008, 05:19
Default Hi all I found the solution
Velan
Hi all
I found the solution for my problem. Please find it in the below link.
http://www.cfd-online.com/cgi-bin/Op...ow.cgi?1/10322
Old   June 30, 2009, 16:57
Frank Regan
Franklin is on a distinguished road
I had a very similar problem, the solution for me was to install cmake and add the library libmpfr from synaptic.
Hope this helps.
Frank
Franklin is offline   Reply With Quote
udf compile error rawin FLUENT 9 August 15, 2005 06:29
UDF Compile Error Quak FLUENT 3 July 20, 2005 09:31
UDF compile error ernest FLUENT 0 July 14, 2005 11:04
Help for udf compile error richard FLUENT 3 October 13, 2003 00:13
Help! UDF Compile Error Michael FLUENT 1 January 18, 2002 17:24
