Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
max for scalarField
Old   November 21, 2008, 08:14
Default max function accepts calls lik
Maka Mohu
maka is on a distinguished road
max function accepts calls like:
volScalarField vsf = ...;
max(vsf, VSMALL);
But does not accept similar calls like:
scalarField sf = ...;
max(sf, VSMALL);
Usually the latter is need when creating boundary condition of wallFunction type. This refers to V1.3; Thanks.
Best regards,
Maka
maka is offline   Reply With Quote
Old   November 21, 2008, 10:40
Default Are you referring to the max m
henry is on a distinguished road
Are you referring to the max member function used for example in the form:
vsf.max(vsf, VSMALL)
H
henry is offline   Reply With Quote
Old   November 21, 2008, 11:03
Default No, I'm revering to the one us
Maka Mohu
No, I'm revering to the one used as a sand-alone function like in:
scalarField x = max(sf,VSMALL);
Thanks.
Old   November 21, 2008, 12:03
Default OK, I will add the equivalents
OK, I will add the equivalents for Field.
H
Old   November 21, 2008, 12:12
Default These functions already exist
These functions already exist in OpenFOAM-1.5 and OpenFOAM-1.5.x
H
Old   November 21, 2008, 12:53
Default Thanks Henry.
Maka Mohu
Thanks Henry.
Old   February 19, 2009, 09:23
Default Hi, max and min function in
Maka Mohu
max and min function in the following code behaves correctly (they consider cell and patch values) but gMax, gMin does not (they only consider cell value but NOT the patch values)
// calculate unit vector in wall normal direction for the boundary patches.
volVectorField wallNormal(reflectionVectors(mesh_).n());
Info << "gMax,gMin(wallNormal)" << gMax(wallNormal) << " " << gMin(wallNormal) << endl;
Info << "max,min(wallNormal)" << max(wallNormal) << " " << min(wallNormal) << endl;
This is V1.3
Best regards,
Maka.
Old   February 19, 2009, 10:05
Default gMax and gMin are defined for
gMax and gMin are defined for Field not GeometricField and calling them for a GeometricField simply calls the functions defined for the internal field as you have found. The GeometricField max and min call gMax and gMin of the internal Field and boundary FieldField. So the behavior you see is the design behavior.
H
Old   February 19, 2009, 10:19
Default Thanks Henry. This means that
Maka Mohu
Thanks Henry. This means that the user only need to call min and max and they will work in parallel, right?
Best regards,
Maka.
Old   February 19, 2009, 10:43
Default For GeometricField max and min
For GeometricField max and min work in parallel, i.e. they do reductions over the processors. For Field max and min do not do reductions as this would not be the correct default behavior for all usages of Field and gMax and gMin should be used if the parallel-reduced value is required.
H
How to sum up scalarField wese OpenFOAM Running, Solving & CFD 2 August 19, 2019 18:30
How to set up an AUTO_WRITE scalarField xiao OpenFOAM Running, Solving & CFD 9 July 22, 2010 04:23
ScalarField division maka OpenFOAM Pre-Processing 2 August 27, 2007 06:10
[CGNS] Computing a cellcentered scalarField from a vertexcentered scalarField mbeaudoin OpenFOAM Meshing & Mesh Conversion 10 February 22, 2007 08:43
Replacing components in a scalarField grtabor OpenFOAM Running, Solving & CFD 1 February 5, 2007 13:24
