March 10, 2009, 00:06 |
Hi All,
I am trying t
#21 |
Vishal Nandigana
Rep Power: 18 |
Hi All,
I am trying to incorporate oscillating fixed value boundary condition in my code for a simple rectangular geometry... I want to incorporate boundary condition given as A * sin (wt).. I did try to implement Oscillating Fixed value... I wanted to add A*sin(wt) as my boundary condition for my Phi variable .. All I did was I changed the oscillatingFixedValue.C file which had 1+Asin(wt) to Asin(wt) and gave wmake libso in the /openfoam/openFOAM-1.5/src/finitevolume directory then gave wmake to my solver... But I didn't see any change in the internalfield values for my Phi when I changed condition from 1+Asin(wt) to Asin(wt)... Further I tried to incorporate these oscillatingfixedvalue.C and .H files in my solver folder directly and gave wmake but I got the following error vishal@vishal-laptop:~/OpenFOAM/vishal-1.5/run/PNP_working_code_500_by_30nm_geometry_5V_transient/co upledFoam$ wmake SOURCE=oscillatingFixedValueFvPatchField.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/vishal/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/vishal/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/vishal/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/oscillatingFixedValueFvPatchField.o oscillatingFixedValueFvPatchField.C:38: error: redefinition of 'Foam::scalar Foam::oscillatingFixedValueFvPatchField<type>::cur rentScale() const' oscillatingFixedValueFvPatchField.C:38: error: 'Foam::scalar Foam::oscillatingFixedValueFvPatchField<type>::cur rentScale() const' previously declared here oscillatingFixedValueFvPatchField.C:53: error: redefinition of 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::fvPatch&, const Foam::DimensionedField<type,>&)' oscillatingFixedValueFvPatchField.C:53: error: 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::fvPatch&, const Foam::DimensionedField<type,>&)' previously declared here oscillatingFixedValueFvPatchField.C:70: error: redefinition of 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::oscillatingFixedValueFvPatchField<type>&, const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::fvPatchFieldMapper&)' oscillatingFixedValueFvPatchField.C:70: error: 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::oscillatingFixedValueFvPatchField<type>&, const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::fvPatchFieldMapper&)' previously declared here oscillatingFixedValueFvPatchField.C:86: error: redefinition of 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::dictionary&)' oscillatingFixedValueFvPatchField.C:86: error: 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::fvPatch&, const Foam::DimensionedField<type,>&, const Foam::dictionary&)' previously declared here oscillatingFixedValueFvPatchField.C:112: error: redefinition of 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::oscillatingFixedValueFvPatchField<type>&)' oscillatingFixedValueFvPatchField.C:112: error: 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::oscillatingFixedValueFvPatchField<type>&)' previously declared here oscillatingFixedValueFvPatchField.C:127: error: redefinition of 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::oscillatingFixedValueFvPatchField<type>&, const Foam::DimensionedField<type,>&)' oscillatingFixedValueFvPatchField.C:127: error: 'Foam::oscillatingFixedValueFvPatchField<type>::os cillatingFixedValueFvPatchFi eld(const Foam::oscillatingFixedValueFvPatchField<type>&, const Foam::DimensionedField<type,>&)' previously declared here oscillatingFixedValueFvPatchField.C:143: error: redefinition of 'void Foam::oscillatingFixedValueFvPatchField<type>::aut oMap(const Foam::fvPatchFieldMapper&)' oscillatingFixedValueFvPatchField.C:143: error: 'virtual void Foam::oscillatingFixedValueFvPatchField<type>::aut oMap(const Foam::fvPatchFieldMapper&)' previously declared here oscillatingFixedValueFvPatchField.C:155: error: redefinition of 'void Foam::oscillatingFixedValueFvPatchField<type>::rma p(const Foam::fvPatchField<type>&, const Foam::labelList&)' oscillatingFixedValueFvPatchField.C:155: error: 'virtual void Foam::oscillatingFixedValueFvPatchField<type>::rma p(const Foam::fvPatchField<type>&, const Foam::labelList&)' previously declared here oscillatingFixedValueFvPatchField.C:167: error: redefinition of 'void Foam::oscillatingFixedValueFvPatchField<type>::upd ateCoeffs()' oscillatingFixedValueFvPatchField.C:167: error: 'virtual void Foam::oscillatingFixedValueFvPatchField<type>::upd ateCoeffs()' previously declared here oscillatingFixedValueFvPatchField.C:188: error: redefinition of 'void Foam::oscillatingFixedValueFvPatchField<type>::wri te(Foam:stream&) const' oscillatingFixedValueFvPatchField.C:188: error: 'virtual void Foam::oscillatingFixedValueFvPatchField<type>::wri te(Foam:stream&) const' previously declared here make: *** [Make/linuxGccDPOpt/oscillatingFixedValueFvPatchField.o] Error 1 I am also attaching the oscillatingfixedvalues files along with my phi boundary condition file.. Kindly have a look at them and give your suggestions..Kindly let me know how to proceed further. Thanks Regards Vishal |
March 10, 2009, 00:27 |
http://www.cfd-online.com/Ope
#22 |
Vishal Nandigana
Rep Power: 18 |
April 8, 2009, 12:18 |
#23 |
Andreas Feymark
Rep Power: 17 |
Hi Hrv,
You asked for a preference. I think that most people would prefer something like, return refValue + amplitude*sin(2*pi*frequency*t); You could of course compile your own local version. But it's much more convenient to have it in a logical way from the beginning. Keep up the good work! /Feymark |
April 28, 2009, 19:52 |
High Mean Drag Using oscillatingFixedValue in 1.4.1-dev
#24 |
Saman
Hi every body,
I have done the corrections recommended in this thread to get an oscillationg cylinder motion and solve it with icoDyMFoam solver. I changed both files in : OpenFoam-1.4.1-dev/src/OpenFOAM/PointPatchFields/derived/oscillatingFixedValue/oscillatingFixedValuePointPatchField.C and them ./Allwmake in src/tetDocompositionFiniteElement OpenFOAM.1.4.1-dev/src/finiteVolume/fields/fvPatchFields/derived/oscillatingFixedValue/oscillatingFixedValueFvPatchField.C and then wmake libso in src/FiniteVolume. When I move the mesh by moveDynamicMesh the mesh seems to move ok . My goal is to obtain the results of Frank Bos for a plunging cylinder at Re = 185 which has the mean drag coefficient around 1.2. Basically I want y = -Asin(2*pi*f*t) for my cylinder. So I changed the lines in the mentioned files to V = -A*2*pi*f*cos(2*pi*f*t) and then compiled. My settings like motionU, BCs, fvSolution, dynamicMeshDict, ... is exactly the same as those of Frank but I get mean drag coefficient equal to 1.7 which is 40% of. Please let me know your suggesstions because what ever is recommended in the forum I have done. I will post the case if any body is willing to take a look. Thanks so much |
August 11, 2015, 08:37 |
#25 |
Stephanie
Rep Power: 11 |
Helle everyone,
I would like to use oscillatingFixedValue in Foam ext. 3.1 In my case I habe a channel with one foil in it. At the inlet the fluid should oscillate, but at the moment it doesn't. I use the following BC for the inlet: { type oscillatingFixedValue; refValue uniform (1.56 0 0); // offset amplitude 0.0577; frequency 0.8367; value uniform (1.56 0 0); } The velocity should be 1.56, amplitude and frequency are clear. Might anyone explain my what value, refvalue and offset mean? Or are there any other BC for such an oscillating velocity? Thank you for anyones' help, best regards, Stephie |
May 29, 2016, 00:06 |
#26 |
Rep Power: 10 |
Hi Stephanie!
I have the same doubt as you... Do you already know what are refvalue and offset? Cheers Ion |
June 7, 2016, 07:32 |
#27 |
Stephanie
Rep Power: 11 |
Dear Ion,
in the end I didn't use offset and refvalue. I changed in the dynamicMeshDict: so lidBodyMotionFunction o s c i l l a t i n g R o t a t i n g M o t i o n ; oscillatingRotatingMotionCoeffs { origin (0.05 0 0); amplitude ( 0 0 3 0 ) ; // i n Grad omega 3 0 1 . 2 1 2 ; // rad / s } The reason why it didn't move, was that I expected the amplitude is a value - but it was an angle. I am sorry, but I can't remember what offset and refvalue mean. I hope this will help you. best regards, Stephie |
July 6, 2016, 23:24 |
#28 | |
Fei Fan
Rep Power: 13 |
I have built my oscillation flow, and In the model, the Vof method was included. When silmulation begin, the volume of fluid will decrease gradually, I thought it was the problem of outlet boundary. I have test the condition of inletOutlet and zeroGradient. But they didn't work. so I want to know which boundary condition used in your model. Best regards Fan Fei |
Piston motion with time varying experimental data oscillatingFixedValue | eno | OpenFOAM Running, Solving & CFD | 3 | March 19, 2009 10:06 |
Piston motion with time varying experimental data oscillatingFixedValue | eno | OpenFOAM Running, Solving & CFD | 0 | March 12, 2009 17:31 |
OscillatingFixedValue in OpenFOAM 141dev | mathieu | OpenFOAM Bugs | 0 | September 9, 2008 17:50 |
141dev svn repository | egp | OpenFOAM Installation | 1 | August 25, 2008 16:10 |
SonicFoam 141dev changes what do they mean | mike_jaworski | OpenFOAM Running, Solving & CFD | 0 | December 30, 2007 15:55 |
