March 12, 2009, 06:06 |
I did a slight modification to
BastiL
Rep Power: 20 |
src/OpenFOAM/interpolations/GGIInterpolation/GGIInterpolationWeights.C This is to get an idea which ggi is making troubles: Line 88: Info << "Evaluation of GGI weighting factors, Master size: " << masterPatch_.size() <<" Slave size: " << slavePatch_.size() << endl; This help me to get a idea which of my ggis is currently worked on. I would prefer tho have patch names instead of size in there but could not manage this so far. Regards. |
March 12, 2009, 16:56 |
Sorry, no names at this stage:
Hrvoje Jasak
Rep Power: 33 |
Sorry, no names at this stage: GGI is a general interpolation stencil so it does not know if you are using it in patches or not. It may be better to have a message somewhere in ggiPolyPatch and similar. Would that help?
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
March 12, 2009, 17:10 |
In my eyes every message that
BastiL
Rep Power: 20 |
In my eyes every message that gives some feedback which patch is currently worked on will help. I have lots of patches and it is exteemly difficult to find out which patch causes troubles without output.
Regards |
June 9, 2009, 09:09 |
BastiL
Rep Power: 20 |
I still have the same problem with the latest svn-Version. we still get no feedback which of the multiple ggis has warnings and which are ok. Would be fine to get some patch or zone info.
Regards. |
June 9, 2009, 22:41 |
Martin Beaudoin
Rep Power: 22 |
Hello BastiL,
Could you post a short sample of the Warning messages you get, so I can see them in context. Martin |
June 10, 2009, 04:15 |
BastiL
Rep Power: 20 |
Yes, I get something like that:
Evaluation of GGI weighting factors: From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const in file /opt/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 533 Uncovered faces found. On master: 6 on slave: 293 Largest slave weighting factor correction : 0.902866 average: 0.00883992 Largest master weighting factor correction: 0.999958 average: 0.0312591 And I would like to have: Evaluation of GGI weighting factors of <FACE ZONE OR PATCH NAME>: From function void GGIInterpolation<MasterPatch, SlavePatch>::rescaleWeightingFactors() const in file /opt/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/GGIInterpolationWeights.C at line 533 Uncovered faces found. On master: 6 on slave: 293 Largest slave weighting factor correction : 0.902866 average: 0.00883992 Largest master weighting factor correction: 0.999958 average: 0.0312591 This is just because I have more than one ggi and I do not know which interface has partial overlaps... |
June 10, 2009, 04:40 |
Hrvoje Jasak
Rep Power: 33 |
I have just checked in something for you, as suggested by Martin:
meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C Please let me know if this is better. Hrv
June 10, 2009, 10:43 |
BastiL
Rep Power: 20 |
Brilliant! Thanks guys, that is exactly what I was looking for. This is making it much easier for me.
Regards BastiL |
OF 15dev 1094 wmake calculatedPointPatchField s H | obraun | OpenFOAM Installation | 2 | March 5, 2009 04:19 |
InterDyMFoam in 15dev keyword agglomerator is undefined in dictionary | eberberovic | OpenFOAM Running, Solving & CFD | 0 | February 16, 2009 11:17 |
Compiling 15dev and 15x in single precision | bastil | OpenFOAM Installation | 0 | February 5, 2009 05:34 |
Compiling 15dev and 15x in single precision | bastil | OpenFOAM Installation | 0 | February 5, 2009 05:03 |
GGI function ggiCheck in OF 15dev | louisgag | OpenFOAM Running, Solving & CFD | 3 | February 3, 2009 21:08 |
