Anomalous behavious for parallel reactingFoam in OpenFOAM-v2312 |
September 8, 2024, 04:20 |
Aritra Roy Choudhury
Dear community,
I am running a reacting simulation for premixed H2-air gas. I am using k-epsilon turbulence model, PaSR model with Cmix = 0.001, and ode solver for chemistry solving. When running in parallel (in reactingFoam in OpenFOAM-v2312) I am observing discontinuous mass fraction values at the different processor domains. I also tried using OpenFOAM-v2112 with no use. This behaviour is not there when running in serial. This behaviour is only visible for some minor species and not for U, P and T fields. I have attached the contours for reference. Please have a look at them and if anyone has faced the same issue please let me know how did you fixed it. Thank you |
October 6, 2024, 09:17 |
Harsh Anand
Rep Power: 2 |
Hi Aritra,
Have you performed the Grid Independence Study for your mesh? The mesh is likely the issue. The other issue can be a 'relatively large' deltaT value in controlDict. Can you please share the case setup for your case? It is otherwise very difficult to comment on anything in particular. ----------------- Thanks, GeekCFD |
parallel, rans, reactingfoam |
OpenFOAM v2312 - Compressible Steady case - rhoSimpleFoam issue | CFD_SG_01 | OpenFOAM Running, Solving & CFD | 3 | August 26, 2024 09:53 |
OpenFOAM v2312 - Centrifugal Pump case with StarCCM+polymesh | CFD_SG_01 | OpenFOAM Running, Solving & CFD | 3 | August 9, 2024 07:25 |
OpenFoam Combustion SIG | dlahaye | OpenFOAM Announcements from Other Sources | 0 | August 14, 2023 12:39 |
OpenFoam - Simulation suddenly stops, reactingFoam | Vittorio94 | OpenFOAM Programming & Development | 2 | June 25, 2019 04:02 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
