request for surfaceScalarField phi from objectRegistry region0 failed |
August 29, 2024, 06:12 |
Meng Huqi
Rep Power: 2 |
Dear All the professions on CFD-Online:
Yesterday, when I used denseParticleFoam to calculate the particle motions (the version of OpenFoam I used is 9.0), the errors were reported as followings: request for surfaceScalarField phi from objectRegistry region0 failed available objects of type surfaceScalarField are 3 ( phi.air alphaPhi.air alphacf ) However, it should be noted that I customized the boundary condition files, fvschemes and fvsolution files as what tutorials presented. I added the terms of "phi phi.air" in the boundary files, which is shown as followings (take U as the example): FoamFile { format ascii; class volVectorField; location "0"; object U.air; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { INLET { type fixedValue; value uniform (0 0 0); inletVelocity uniform (0 0 0); phi phi.air alpha alpha.air; } FAR { type fixedValue; value uniform (0 0 0); } OUTLET { type fixedValue; inletValue uniform (0 0 0); value uniform (0 0 0); phi phi.air; } DEVICE { type fixedValue; value uniform (0 0 0); } RESERVOIR { type fixedValue; value uniform (0 0 0); } MOUTHPIECE { type fixedValue; value uniform (0 0 0); } OUTER-FLOWCHANNEL { type fixedValue; value uniform (0 0 0); } DOSE-CUP { type fixedValue; value uniform (0 0 0); } FLOWPATH { type fixedValue; value uniform (0 0 0); } } Did any one know what's wrong. |
Paraview 5.10.1 - error - openfoam 11 - ubuntu 22.04 lts | gu1 | OpenFOAM Bugs | 5 | July 29, 2024 10:50 |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
