Hasan Bugra Ozden
Rep Power: 0 ![]() |
Hi guys,
I am using rhoSimpleFoam and cannot use the linear EoS even if it is defined in the thermophysical properties. I want to investigate the density change by changing just the pressure, not the temperature. The linear EoS condition may give a reasonable solution for my case because the fluid is a liquid.. I got the problem there --> FOAM FATAL IO ERROR: (openfoam-2312) Unknown fluidThermo type Valid fluidThermo types : my file FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState linear; specie specie; energy sensibleInternalEnergy; } mixture { specie { nMoles 1; molWeight 100; // Example molar weight for oil } equationOfState { psi 670e-12; // Compressibility coefficient rho0 860; // Reference density } thermodynamics { Cp 2500; // Specific heat capacity Hf 0; // Formation enthalpy } transport { mu 0.03999; // Viscosity Pr 0.7; // Prandtl number } } |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Optimal tolerance and variables scaling settings | 4513645ygq | Main CFD Forum | 0 | July 28, 2020 08:56 |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
A turbulent test case for rhoCentralFoam | immortality | OpenFOAM Running, Solving & CFD | 13 | April 20, 2014 06:32 |
