Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OpenFoam crashes without error message
Old   June 4, 2024, 04:57
Default OpenFoam crashes without error message
Clément
InternCFDMallorca is on a distinguished road
Hello everyone, I'm currently working on a hull resistance simulation on OpenFOAM and sometimes my simulation just stops suddenly.
It looks like my WSL just quit.
Here is my terminal commands and as you can see, while running interFoam Ubuntu quits and I go back to Windows terminal.
practicas@DESKTOP-VBCK1B0:~/OpenFOAM-simulations/QHullMovingTest/Fixed018_triangleMesh01_fineMarineLecture$ ./Allrun
Restore 0/ from 0.orig/
Running setFields on /home/practicas/OpenFOAM-simulations/QHullMovingTest/Fixed018_triangleMesh01_fineMarineLecture
Running redistributePar (27 processes) on /home/practicas/OpenFOAM-simulations/QHullMovingTest/Fixed018_triangleMesh01_fineMarineLecture
Running renumberMesh (27 processes) on /home/practicas/OpenFOAM-simulations/QHullMovingTest/Fixed018_triangleMesh01_fineMarineLecture
Running interFoam (27 processes) on /home/practicas/OpenFOAM-simulations/QHullMovingTest/Fixed018_triangleMesh01_fineMarineLecture
PS C:\Users\Practicas>
If I look at the interFoam log file, there is no error message.
GAMG:  Solving for p_rgh, Initial residual = 0.00135089, Final residual = 9.47443e-08, No Iterations 121
time step continuity errors : sum local = 5.57671e-10, global = 3.5032e-12, cumulative = 1.67191e-07
smoothSolver:  Solving for omega, Initial residual = 2.66142e-05, Final residual = 7.09206e-07, No Iterations 1
bounding omega, min: -10.993 max: 1166.84 average: 1.73472
smoothSolver:  Solving for k, Initial residual = 0.000225124, Final residual = 7.6232e-06, No Iterations 1
bounding k, min: -5.26507e-06 max: 0.000448989 average: 5.06676e-08
ExecutionTime = 354.6 s  ClockTime = 354 s
forces forces write:
    Sum of forces
        Total    : (-120401 2.65429e+06 1.07362e+07)
        Pressure : (-95618.6 2.65451e+06 1.07364e+07)
        Viscous  : (-24782.3 -213.074 -237.383)
    Sum of moments
        Total    : (-8.6902e+06 1.4437e+09 -3.5167e+08)
        Pressure : (-8.69147e+06 1.44344e+09 -3.51534e+08)
        Viscous  : (1265.9 265180 -136120)
    writing force and moment files.
Flow time scale min/max = 0.00108217, 1
Smoothed flow time scale min/max = 0.00108217, 1
Damped flow time scale min/max = 0.00108217, 1
Time = 2.38
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 3.30283e-06, Final residual = 2.14453e-10, No Iterations 2
Phase-1 volume fraction = 0.681744  Min(alpha.water) = -1.54842e-06  Max(alpha.water) = 1
Applying the previous iteration compression flux
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.681744  Min(alpha.water) = -1.52536e-05  Max(alpha.water) = 1.00002
GAMG:  Solving for p_rgh, Initial residual = 0.00990431, Final residual = 9.77604e-05, No Iterations 15
time step continuity errors : sum local = 6.86426e-07, global = 9.26118e-09, cumulative = 1.76452e-07
GAMG:  Solving for p_rgh, Initial residual = 0.00121946, Final residual = 9.49064e-08, No Iterations 94
time step continuity errors : sum local = 6.50577e-10, global = -3.92438e-12, cumulative = 1.76448e-07
smoothSolver:  Solving for omega, Initial residual = 3.44185e-05, Final residual = 1.13756e-06, No Iterations 1
bounding omega, min: -3.65773 max: 1108.88 average: 1.80655
smoothSolver:  Solving for k, Initial residual = 0.000315802, Final residual = 1.0958e-05, No Iterations 1
bounding k, min: -1.66911e-06 max: 0.000737659 average: 8.39992e-08
ExecutionTime = 364.84 s  ClockTime = 365 s
    Sum of forces
        Total    : (-116858 2.65596e+06 1.07454e+07)
        Pressure : (-93538.
Has someone allready encountered this situation?
InternCFDMallorca is offline   Reply With Quote
crash, openfoam v2312, ubuntu, wsl
OpenFoam Case crashes using swak4Foam Miguel.Mendez Main CFD Forum 2 March 24, 2021 00:42
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
