Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OpenFoam over-dissipating energy
Old   April 22, 2024, 08:12
Post OpenFoam over-dissipating energy
Enrico DL
enricodl is on a distinguished road
Hi everyone,
I am running a Homogeneous Isotropic Turbulence (HIT) case with LES (Smagorinsky) on OF2306 .
The case is a tutorial in:
$FOAM_TUTORIALS/incompressible/pimpleFoam/LES/decayIsoTurb
The case is already set up to export the energy density spectrum.
The problem is that the result spectrum decays in time much quicker than the reference case ( in 1 simulation second it decays 2 orders of magnitude more than CBC).
The reference is from Comte-Bellot and Corrsin wind tunnel(1971).
Things that I have tried:
1) remove LES model. by running the simulation in "laminar" mode, the inertial range decays the same quick, but there is a pile up of energy at the unresolved modes (the spectrum, instead of being monothonic decreasing, presents a local maximum after the filter cutoff mode), as expected.
2) reduce viscosity from 1e-5 (default value in the tutorial) to 1e-6 (value close to the one obtained from a dimensionless analysis to fix the same Re_lambda as CBC ( Re_lambda=71.6 , see Pope, Chp. 6 Sec. 3 ).
It didn't almost change the result at all. It make look like there is a "residual" (sorry for the mis-use of notation) viscosity that is much bigger than the Nu. Though, I'm not using upwind or any diffusive scheme ( I guess? Can you recognise the source of this diffusion in the fvSchemes and fvSolution case files.)
3) increase mesh from 64^3 to 128^3 : didn't change much, since 64^3 is already documented to be resolving this case ( classical HIT with LES )
4) (other less relevant things, like trying v.2206 and 2312)
To reproduce the behavior just:
-copy case from OF tutorials to your directory
-remember to change:
endTime= 2
writeFormat=ascii
-you can use Allrun (it's a small case and using the cluster isn't necessary)
enricodl is offline   Reply With Quote
hit energy spectrum, les, openfoam
Turbulence dissipation vs Viscous dissipation granzer Main CFD Forum 18 January 10, 2022 01:27
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 14, 2016 11:19
Energy equation in OpenFoam nwpukaka OpenFOAM Programming & Development 2 June 24, 2014 03:40
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
