Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Simulation failed; Parallel computing in OpenFOAM
Old   March 3, 2024, 18:51
Unhappy Simulation failed; Parallel computing in OpenFOAM
Hazem
hazem1 is on a distinguished road
Hello everyone,
I have a problem in running a parallel simulation with OpenFOAM on HPC.
I have a case that I used to run it smoothly on 40 processors. The same case now keeps failing without changing any of the input files.
I doubted that the problem is the version of openMPI, so I re-compliled OpenFOAM with a newer version of OpenMPI, but this didn't solve the problem.
Besides, I tried to run the case on a fewer number of processors. It ran without any problems on 4, 8 and 12 processors, and it failed on 16 and higher. The node of our HPC has 20 processors, so it failed even if it should be on the same node.
I tried also to remove the current version of OpenFOAM, and I installed the latest version, but this also doesn't help.
Has anyone encountered a similar problem? And how should I fix this?
Attached, screenshots of the log files at the line at which the simulation continues or fails. (after "Create time")
hazem1 is offline   Reply With Quote
Old   June 3, 2024, 11:52
Adriana Pinto
AdrianaPinto2 is on a distinguished road
Originally Posted by hazem1 View Post
Hello everyone,
Attachment 98749
Attachment 98750
Hello Hazem. Did you find a solution to this problem? I think I am having a similar problem.
AdrianaPinto2 is offline   Reply With Quote
Old   July 20, 2024, 00:17
kol1978 is on a distinguished road
I'm also interested in this topic...
What commands do you use to run multi-threading and multi-core?
kol1978 is offline   Reply With Quote
Old   July 22, 2024, 03:23
Hazem
Yes, I have found a temporary solution to this problem by commenting these lines in etc/bashrc file of openfoam
#- Floating-point signal handling:
# set or unset
#export FOAM_SIGFPE=
#- memory initialisation:
# set or unset
#export FOAM_SETNAN=
Old   July 22, 2024, 23:36
# set or unset
# set or unset
How can you explain the “way” to achieve the result? does this mean that messages are just ignored...or is it something else? PS sorry for the curiosity.
Old   July 23, 2024, 00:06
# set or unset
# set or unset
I have version 12... and in it export FOAM_SETNAN= is commented out by default... - FYI
Time = 499s
DILUPBiCGStab: Solving for Ux, Initial residual = 0.99850453006779127385, Final residual = 0.00010498198180043912865, No Iterations 1
DILUPBiCGStab: Solving for Uy, Initial residual = 0.99998959877070658919, Final residual = 0.031512857985444418796, No Iterations 2
DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 0.019798126998869420429, No Iterations 2
GAMG: Solving for p, Initial residual = 1, Final residual = 2.0185126205988228598, No Iterations 1000
time step continuity errors : sum local = 5.146150313434651517e+33, global = -9.0143693102528848905e+31, cumulative = -9.0143693044835395807e+31
limitPressure: min -2.9014427041733308485e+67
limitPressure: max 1.171646142087871299e+67
DILUPBiCGStab: Solving for omega, Initial residual = 0.16904390887232240148, Final residual = 0.0033324748957708474548, No Iterations 1
DILUPBiCGStab: Solving for k, Initial residual = 0.16350213330906379627, Final residual = 0.010349788792748771532, No Iterations 1
ExecutionTime = 20.375533999999998258 s ClockTime = 23 s
Time = 500s
DILUPBiCGStab: Solving for Ux, Initial residual = 0.82662523492615680443, Final residual = 0.026385557104654375898, No Iterations 208
DILUPBiCGStab: Solving for Uy, Initial residual = 0.72158252182498183736, Final residual = 0.010988437993210267707, No Iterations 203
[3] #0 [1] [2] #0 Foam::error:rintStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
at ??:?
[3] #1 Foam::sigFpe::sigHandler(int)[2] #1 Foam::sigFpe::sigHandler(int) at ??:?
[2] #2 ? at ??:?
[1] #2 ? at ??:?
[0] #2 ? at ??:?
[3] #2 ? in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[2] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[3] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[2] #4 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[1] #4 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #4 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[1] #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[2] #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[3] #4 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[3] #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[2] #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[1] #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[0] #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[3] #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[2] #7 Foam::fvMatrix<double>::solve() at ??:?
[1] #7 Foam::fvMatrix<double>::solve() at ??:?
[0] #7 Foam::fvMatrix<double>::solve() at ??:?
[3] #7 Foam::fvMatrix<double>::solve() at ??:?
[2] #8 Foam::solvers::fluid::thermophysicalPredictor() at ??:?
[2] #9 at ??:?
[1] #8 Foam::solvers::fluid::thermophysicalPredictor() at ??:?
[1] #9 ?? in "/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/bin/foamRun"
[1] #10 ? in "/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/bin/foamRun"
[2] #10 ? at ??:?
[0] #8 Foam::solvers::fluid::thermophysicalPredictor() in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[1] #11 __libc_start_main in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[2] #11 __libc_start_main in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[1] #12 at ??:?
[3] #8 Foam::solvers::fluid::thermophysicalPredictor() at ??:?
[0] #9 in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[2] #12 at ??:?
[3] #9 ???? in "/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/bin/foamRun"
[kol-VirtualBox:165236] *** Process received signal ***
[kol-VirtualBox:165236] Signal: Floating point exception (8)
[kol-VirtualBox:165236] Signal code: (-6)
[kol-VirtualBox:165236] Failing at address: 0x3e800028574
[kol-VirtualBox:165236] [ 0] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x706210445320]
[kol-VirtualBox:165236] [ 1] /usr/lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x11c)[0x70621049eb1c]
[kol-VirtualBox:165236] [ 2] /usr/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x1e)[0x70621044526e]
[kol-VirtualBox:165236] [ 3] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x706210445320]
[kol-VirtualBox:165236] [ 4] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_ EES5_+0x3e)[0x706211406ede]
[kol-VirtualBox:165236] [ 5] in "/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/bin/foamRun"
[kol-VirtualBox:165235] *** Process received signal ***
[kol-VirtualBox:165235] Signal: Floating point exception (8)
[kol-VirtualBox:165235] Signal code: (-6)
[kol-VirtualBox:165235] Failing at address: 0x3e800028573
[kol-VirtualBox:165235] [ 0] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x7b1f40a45320]
[kol-VirtualBox:165235] [ 1] /usr/lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x11c)[0x7b1f40a9eb1c]
[kol-VirtualBox:165235] [ 2] /usr/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x1e)[0x7b1f40a4526e]
[kol-VirtualBox:165235] [ 3] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x7b1f40a45320]
[kol-VirtualBox:165235] [ 4] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_ EES5_+0x3e)[0x7b1f41a06ede]
[kol-VirtualBox:165235] [ 5] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam9PBiCGStab5solveERNS_5Fiel dIdEERKS2_h+0x7a1)[0x7062111cc561]
[kol-VirtualBox:165236] [ 6] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegr egatedERKNS_10dictionaryE+0x24f)[0x7062126584ff]
[kol-VirtualBox:165236] [ 7] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam9PBiCGStab5solveERNS_5Fiel dIdEERKS2_h+0x7a1)[0x7b1f417cc561]
[kol-VirtualBox:165235] [ 6] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x302)[0x706212134852]
[kol-VirtualBox:165236] [ 8] in "/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/bin/foamRun"
[0] #10 ?/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveEv+0x 8d)[0x706212147f3d]
[kol-VirtualBox:165236] [ 9] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfluid.so(_ZN4Foam7solvers5fluid23thermophysical PredictorEv+0x53a)[0x70620c183f1a]
/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegr egatedERKNS_10dictionaryE+0x24f)[0x7b1f42c584ff]
[kol-VirtualBox:165235] [ 7] [kol-VirtualBox:165236] [10] foamRun(+0x3df2)[0x5deb10210df2]
[kol-VirtualBox:165236] [11] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x2a1ca)[0x70621042a1ca]
[kol-VirtualBox:165236] [12] /usr/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x8b)[0x70621042a28b]
[kol-VirtualBox:165236] [13] foamRun(+0x4565)[0x5deb10211565]
[kol-VirtualBox:165236] *** End of error message ***
/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x302)[0x7b1f42734852]
[kol-VirtualBox:165235] [ 8] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveEv+0x 8d)[0x7b1f42747f3d]
[kol-VirtualBox:165235] [ 9] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfluid.so(_ZN4Foam7solvers5fluid23thermophysical PredictorEv+0x53a)[0x7b1f3c363f1a]
[kol-VirtualBox:165235] [10] foamRun(+0x3df2)[0x5bb987be5df2]
[kol-VirtualBox:165235] [11] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x2a1ca)[0x7b1f40a2a1ca]
[kol-VirtualBox:165235] [12] /usr/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x8b)[0x7b1f40a2a28b]
[kol-VirtualBox:165235] [13] foamRun(+0x4565)[0x5bb987be6565]
[kol-VirtualBox:165235] *** End of error message ***
[3] #10 ? in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[0] #11 __libc_start_main in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[3] #11 __libc_start_main in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[0] #12 in "/usr/lib/x86_64-linux-gnu/libc.so.6"
[3] #12 ? in ?"/home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/bin/foamRun"
[kol-VirtualBox:165237] *** Process received signal ***
[kol-VirtualBox:165237] Signal: Floating point exception (8)
[kol-VirtualBox:165237] Signal code: (-6)
[kol-VirtualBox:165237] Failing at address: 0x3e800028575
[kol-VirtualBox:165237] [ 0] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x765179c45320]
[kol-VirtualBox:165237] [ 1] /usr/lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x11c)[0x765179c9eb1c]
[kol-VirtualBox:165237] [ 2] /usr/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x1e)[0x765179c4526e]
[kol-VirtualBox:165237] [ 3] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x765179c45320]
[kol-VirtualBox:165237] [ 4] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_ EES5_+0x3e)[0x76517ac06ede]
[kol-VirtualBox:165237] [ 5] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam9PBiCGStab5solveERNS_5Fiel dIdEERKS2_h+0x7a1)[0x76517a9cc561]
[kol-VirtualBox:165237] [ 6] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegr egatedERKNS_10dictionaryE+0x24f)[0x76517be584ff]
[kol-VirtualBox:165237] [ 7] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x302)[0x76517b934852]
[kol-VirtualBox:165237] [ 8] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveEv+0x 8d)[0x76517b947f3d]
[kol-VirtualBox:165237] [ 9] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfluid.so(_ZN4Foam7solvers5fluid23thermophysical PredictorEv+0x53a)[0x76517806bf1a]
[kol-VirtualBox:165237] [10] foamRun(+0x3df2)[0x5c013c4e7df2]
[kol-VirtualBox:165237] [11] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x2a1ca)[0x765179c2a1ca]
[kol-VirtualBox:165237] [12] /usr/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x8b)[0x765179c2a28b]
[kol-VirtualBox:165237] [13] foamRun(+0x4565)[0x5c013c4e8565]
[kol-VirtualBox:165237] *** End of error message ***
[kol-VirtualBox:165234] *** Process received signal ***
[kol-VirtualBox:165234] Signal: Floating point exception (8)
[kol-VirtualBox:165234] Signal code: (-6)
[kol-VirtualBox:165234] Failing at address: 0x3e800028572
[kol-VirtualBox:165234] [ 0] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x7551db245320]
[kol-VirtualBox:165234] [ 1] /usr/lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x11c)[0x7551db29eb1c]
[kol-VirtualBox:165234] [ 2] /usr/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x1e)[0x7551db24526e]
[kol-VirtualBox:165234] [ 3] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x45320)[0x7551db245320]
[kol-VirtualBox:165234] [ 4] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_ EES5_+0x3e)[0x7551dc206ede]
[kol-VirtualBox:165234] [ 5] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam9PBiCGStab5solveERNS_5Fiel dIdEERKS2_h+0x7a1)[0x7551dbfcc561]
[kol-VirtualBox:165234] [ 6] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegr egatedERKNS_10dictionaryE+0x24f)[0x7551dd4584ff]
[kol-VirtualBox:165234] [ 7] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS _10dictionaryE+0x302)[0x7551dcf34852]
[kol-VirtualBox:165234] [ 8] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveEv+0x 8d)[0x7551dcf47f3d]
[kol-VirtualBox:165234] [ 9] /home/kol/foam/OpenFOAM-12/platforms/linux64GccDPInt32Opt/lib/libfluid.so(_ZN4Foam7solvers5fluid23thermophysical PredictorEv+0x53a)[0x7551d8253f1a]
[kol-VirtualBox:165234] [10] foamRun(+0x3df2)[0x61fae9ecfdf2]
[kol-VirtualBox:165234] [11] /usr/lib/x86_64-linux-gnu/libc.so.6(+0x2a1ca)[0x7551db22a1ca]
[kol-VirtualBox:165234] [12] /usr/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x8b)[0x7551db22a28b]
[kol-VirtualBox:165234] [13] foamRun(+0x4565)[0x61fae9ed0565]
[kol-VirtualBox:165234] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 2 with PID 0 on node kol-VirtualBox exited on signal 8 (Floating point exception).
didn't help me...
parallel computing
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
OpenFOAM solvers not able to run in parallel raagh77 OpenFOAM Installation 5 November 27, 2013 18:05
Testing OpenFOAM parallel computing jason.ryon OpenFOAM 0 October 5, 2009 12:46
