Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
openfoam dsmcFoamPlus error
Old   November 10, 2023, 09:37
Default openfoam dsmcFoamPlus error
lihui
lihuihh is on a distinguished road
I ues dsmcFoamPlus module to calculate. An error occurred during the process.The error information is as follows:
[123] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[123] #1 Foam::sigFpe::sigHandler(int) at ??:?
[123] #2 ? in "/lib64/libc.so.6"
[123] #3 log in "/lib64/libm.so.6"
[123] #4 Foam::dsmcCloud::equipartitionVibrationalEnergyLev el(double, double, int) at ??:?
[123] #5 Foam::dsmcMixedDiffuseSpecularWallRotationPatch::c ontrolParticle(Foam::dsmcParcel&, Foam::dsmcParcel::trackingData&) at ??:?
[123] #6 double Foam:article::trackToFace<Foam::dsmcParcel::trac kingData>(Foam::Vector<double> const&, Foam::dsmcParcel::trackingData&, bool) at ??:?
[123] #7 Foam::dsmcParcel::move(Foam::dsmcParcel::trackingD ata&, double) at ??:?
[123] #8 void Foam::Cloud<Foam::dsmcParcel>::move<Foam::dsmcParc el::trackingData>(Foam::dsmcParcel::trackingData&, double) at ??:?
[123] #9 Foam::dsmcCloud::evolve() at ??:?
[123] #10 ? at ??:?
[123] #11 __libc_start_main in "/lib64/libc.so.6"
[123] #12 ? at ??:?
[h13r4n06:60765:0:60765] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2))
==== backtrace (tid: 60765) ====
0 0x0000000000036280 killpg() ???:0
1 0x0000000000036207 __GI_raise() :0
2 0x0000000000036280 killpg() ???:0
3 0x0000000000026313 __log() :0
4 0x00000000000baa65 Foam::dsmcCloud::equipartitionVibrationalEnergyLev el() ???:0
5 0x00000000001e12ba Foam::dsmcMixedDiffuseSpecularWallRotationPatch::c ontrolParticle() ???:0
6 0x00000000000b2e15 Foam:article::trackToFace<Foam::dsmcParcel::trac kingData>() ???:0
7 0x00000000000a4969 Foam::dsmcParcel::move() ???:0
8 0x00000000000d4cc1 Foam::Cloud<Foam::dsmcParcel>::move<Foam::dsmcParc el::trackingData>() ???:0
9 0x00000000000c27bf Foam::dsmcCloud::evolve() ???:0
10 0x0000000000401e77 main() ???:0
11 0x00000000000223d5 __libc_start_main() ???:0
12 0x00000000004021cd _start() ???:0
[h13r4n06:60765] *** Process received signal ***
[h13r4n06:60765] Signal: Floating point exception (8)
[h13r4n06:60765] Signal code: (-6)
[h13r4n06:60765] Failing at address: 0x36c60000ed5d
[h13r4n06:60765] [ 0] /lib64/libc.so.6(+0x36280)[0x2abc637a1280]
[h13r4n06:60765] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x2abc637a1207]
[h13r4n06:60765] [ 2] /lib64/libc.so.6(+0x36280)[0x2abc637a1280]
[h13r4n06:60765] [ 3] /lib64/libm.so.6(log+0x43)[0x2abc63279313]
[h13r4n06:60765] [ 4] /work/home/ackc9ufnjv/OpenFOAM/OpenFOAM-2.4.0-MNF/platforms/linux64GccMNFDPOpt/lib/libdsmcFOAM.so(_ZN4Foam9dsmcCloud35equipartitionVi brationalEnergyLevelEddi+0xeb)[0x2abc61b70a65]
[h13r4n06:60765] [ 5] /work/home/ackc9ufnjv/OpenFOAM/OpenFOAM-2.4.0-MNF/platforms/linux64GccMNFDPOpt/lib/libdsmcFOAM.so(_ZN4Foam41dsmcMixedDiffuseSpecularW allRotationPatch15controlParticleERNS_10dsmcParcel ERNS1_12trackingDataE+0x790)[0x2abc61c972ba]
[h13r4n06:60765] [ 6] /work/home/ackc9ufnjv/OpenFOAM/OpenFOAM-2.4.0-MNF/platforms/linux64GccMNFDPOpt/lib/libdsmcFOAM.so(_ZN4Foam8particle11trackToFaceINS_1 0dsmcParcel12trackingDataEEEdRKNS_6VectorIdEERT_b+ 0x3563)[0x2abc61b68e15]
[h13r4n06:60765] [ 7] /work/home/ackc9ufnjv/OpenFOAM/OpenFOAM-2.4.0-MNF/platforms/linux64GccMNFDPOpt/lib/libdsmcFOAM.so(_ZN4Foam10dsmcParcel4moveERNS0_12tr ackingDataEd+0x131)[0x2abc61b5a969]
[h13r4n06:60765] [ 8] /work/home/ackc9ufnjv/OpenFOAM/OpenFOAM-2.4.0-MNF/platforms/linux64GccMNFDPOpt/lib/libdsmcFOAM.so(_ZN4Foam5CloudINS_10dsmcParcelEE4mo veINS1_12trackingDataEEEvRT_d+0x8a1)[0x2abc61b8acc1]
[h13r4n06:60765] [ 9] /work/home/ackc9ufnjv/OpenFOAM/OpenFOAM-2.4.0-MNF/platforms/linux64GccMNFDPOpt/lib/libdsmcFOAM.so(_ZN4Foam9dsmcCloud6evolveEv+0x97)[0x2abc61b787bf]
[h13r4n06:60765] [10] dsmcFoamPlus[0x401e77]
[h13r4n06:60765] [11] /lib64/libc.so.6(__libc_start_main+0xf5)[0x2abc6378d3d5]
[h13r4n06:60765] [12] dsmcFoamPlus[0x4021cd]
[h13r4n06:60765] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 123 with PID 60765 on node h13r4n06 exited on signal 8 (Floating point exception).
lihuihh is offline   Reply With Quote
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 09:40
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
