twoPhaseEuler always diverging on second tStep, no matter from where starts |
Julio Pieri
Rep Power: 8 ![]() |
Hi all!
I'm facing a very weird and enigmatic behavior in my transient twoPhaseEulerFoam simulation of a fluidized bed, which I think might be a bug. I'm using OF v2012, and got the same result with v1812, both on WSL Ubuntu. I've been working on a series of similar cases for over 4 months now, and I have had pretty good results so far. I had to stop a case, as did many times before, but this particular setup won't restart. It always diverges on the second time iteration - no matter if I deleted one, two, ten, whatever, latest timesteps. Smaller timesteps also didn't help. If I write the first timestep re-calculated, I can advance with the solution: it writes the first iteration -> diverges on second tstep -> I resume it -> it writes one more -> diverges again, etc. Looking at paraview, the solution evolves as I would expect, suggesting the setup is ok. I've created a simple case that reproduces this. If I leave it be, fresh start, it runs smoothly with no problems. If I interrupt it anywhere, though, it doesn't restart. The error is the following: Code:
PIMPLE: iteration 1 MULES: Solving for alpha.particles MULES: Solving for alpha.particles smoothSolver: Solving for alpha.particles, Initial residual = 3.29388e-06, Final residual = 2.35206e-10, No Iterations 1 alpha.particles volume fraction = 0.31103 Min(alpha.particles) = 0 Max(alpha.particles) = 0.600047 Constructing momentum equations #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::tmp<Foam::GeometricField<Foam::typeOfMag<Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::mag<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #4 Foam::phasePair::magUr() const at ??:? #5 Foam::phasePair::Re() const at ??:? #6 Foam::heatTransferModels::RanzMarshall::K() const at ??:? #7 Foam::BlendedInterfacialModel<Foam::heatTransferModel>::K() const at ??:? #8 Foam::twoPhaseSystem::Kh() const at ??:? #9 ? at ??:? #10 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #11 ? at ??:? Floating point exception Code:
Foam::tmp<Foam::volScalarField> Foam::phasePair::magUr() const { return mag(phase1().U() - phase2().U()); } If I change the Heat Transfer Model from RanzMarshall to the other available, called spherical, the error changes to: Code:
PIMPLE: iteration 1 MULES: Solving for alpha.particles MULES: Solving for alpha.particles smoothSolver: Solving for alpha.particles, Initial residual = 3.44837e-06, Final residual = 2.4905e-10, No Iterations 1 alpha.particles volume fraction = 0.31103 Min(alpha.particles) = 0 Max(alpha.particles) = 0.600048 Constructing momentum equations smoothSolver: Solving for e.particles, Initial residual = 8.98554e-08, Final residual = 2.86103e-08, No Iterations 1 smoothSolver: Solving for e.air, Initial residual = 0.0395403, Final residual = 3.89446e-07, No Iterations 2 min T.particles 1122.95 min T.air 426 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 #3 Foam::scalarProduct<double, double>::type Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::scalarSolve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:? #6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #9 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? #10 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? #11 ? at ??:? #12 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #13 ? at ??:? Floating point exception Code:
export FOAM_SIGFPE=false Code:
[...] at second timestep: Constructing momentum equations smoothSolver: Solving for e.particles, Initial residual = 8.98554e-08, Final residual = 2.86103e-08, No Iterations 1 smoothSolver: Solving for e.air, Initial residual = 0.0395403, Final residual = 3.89446e-07, No Iterations 2 min T.particles 1122.95 min T.air 426 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = nan, No Iterations 1000 GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 1000 So far, what I've tried:
I've tried eveything I can think of, and I can't manage to overcome the problem. I believe I might be close to a possible OF bug: this might be a very very specific set of parameters - mesh, timescale, velocity, phase fraction, etc - that makes the solver go crazy. I've had several other successful cases running with very similar parameters. And if I fresh start it, it goes well indefinetely!! The difference from this case to the last one that was ok is that this one have a slightly smaller domain (same element size). Attached you can find my case. To reproduce the error, hit Allrun, stop after it writes the first timestep (0.001s), then hit "twoPhaseEulerFoam" to restart it. You can change the heat transfer model inside constant/phaseProperties. Any help or insight is welcome. Thank you very much! |
Julio Pieri
Hi, this problem was related to the "JacksonJohnsonParticleSlip" model. I'm not sure where and why, but I believe it is related to the multiple IF statements. For different pressure values, a different IF condition is trigger. Upon restarting the simulation, it oscillates between two conditions leading to unphysical values and diverges.
When I run without this model, it works. |
diverging, ranzmarshall, second time step, twophaseeulerfoam |
Always diverging on second timestep, no matter from where it begins | JulioPieri | OpenFOAM Running, Solving & CFD | 0 | November 11, 2021 15:34 |
Modeling new matter! | Sunil Hadap | Main CFD Forum | 2 | February 23, 2000 17:06 |
