May 18, 2021, 05:20 |
fvc::grad(U) failing in parallel
Wael Itani
I have a custom boundary condition which computes the gradient of the velocity field to compute its value. It works fine in serial run. However, it fails in parallel.
uName = this->internalField().name(); const volVectorField& U = db().lookupObject<volVectorField>(uName); volTensorField gradU = fvc::grad(U); When the last line is commented it runs fine. Otherwise, it gives the below error. U.size() shows the correct number of cells for the processor. [0] From const T& Foam::UPtrList<T>:perator[](Foam::label) const [with T = Foam::fvPatchField<Foam::Vector<double> >; Foam::label = int] [0] in file /home/user/openfoam/BuildEnv/debian-build/focal-2012.latest/scratch/src/OpenFOAM/lnInclude/UPtrListI.H at line 218. [0] FOAM parallel run aborting [0] [0] #0 Foam::error:rintStack(Foam::Ostream&)[1] [1] [1] --> FOAM FATAL ERROR: (openfoam-2012) [1] Cannot dereference nullptr at index 0 in range [0,12) [1] [1] [1] From const T& Foam::UPtrList<T>:perator[](Foam::label) const [with T = Foam::fvPatchField<Foam::Vector<double> >; Foam::label = int] [1] in file /home/user/openfoam/BuildEnv/debian-build/focal-2012.latest/scratch/src/OpenFOAM/lnInclude/UPtrListI.H at line 218. [1] FOAM parallel run aborting [1] [1] #0 Foam::error:rintStack(Foam::Ostream&)[LAPTOP-U0DBOLPO:28182] 1 more process has sent help message help-mpi-api.txt / mpi-abort [LAPTOP-U0DBOLPO:28182] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages ./runThis.sh: line 5: recomposePar: command not found |
boundary, bug, grad, programming |
[ANSYS Meshing] Parallel meshing utilisation failing | crc1622 | ANSYS Meshing & Geometry | 0 | February 14, 2019 02:42 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing | Regis_ | OpenFOAM Meshing & Mesh Conversion | 2 | June 4, 2015 13:44 |
