Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
PimpleFOAM wind turbine simulation, courant number going way past limit
Old   February 12, 2021, 13:34
Default PimpleFOAM wind turbine simulation, courant number going way past limit
OpenFOAM User is on a distinguished road
I'm trying to run a simulation of a wind turbine in pimpeFOAM with the following commands in this order; surfaceFeatureExtract, blockMesh, snappyHexMesh -overwrite, renumberMesh -overwrite, createPatch -overwrite, checkMesh, pimpleFOAM.
When checkMesh is ran it has one faliure, the max-skewness, it always exceeds it.
The courant number is limited at 1 in the control dict but increases with each iteration, getting in the order of 10^(36) quickly. This is with the adjustTimeStep function turned off. When turned on, delta T increases with order of around 10^(-4 to -6). This is far smaller than specified but it always does it no matter what's specified. The simulation will end very early (in the order of milli-seconds) and unexpectedly because it doesn't even say it's ended when its stop running.
I'm pretty sure the centre of the ami is correctly centred in the dynamicDict as for the small simulation time it can run it appears to rotate properly.
The blockMesh is far less refined than the snappyHexMesh, could this be causing a problem as I've heard that meshes can cause problems?
See below the link to a OneDrive with the case and blender files for the turbine:
https://1drv.ms/u/s!AmEfNs_K9Yf4adhp...o7G-I?e=aTNw6C
Thank you!
OpenFOAM User is offline   Reply With Quote
courant number limit, delta time, mesh problem, pimplefoam, simulation stopping
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Unexpected deltaT decrease in pimpleFoam simulation robyTKD OpenFOAM Running, Solving & CFD 9 June 27, 2014 07:52
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
