Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
fsiFoam bug in installation ? Something deprecated
Old   September 2, 2020, 23:10
Default fsiFoam bug in installation ? Something deprecated
Ra Miro
ramrebol is on a distinguished road
Hello.
I'm trying to install fsiFoam, but I have a problem in Section 3.2 of its install tutorial:
https://openfoamwiki.net/index.php/E...re_interaction
cd FluidSolidInteraction/src ./Allwmake
When I run Allwmake appears the following errors
/home/ramrebol/foam/foam-extend-4.0/src/foam/lnInclude/SLListBaseI.H: In member function ‘Foam::SLListBase::iterator Foam::SLListBase::iterator:perator++(int)’:
/home/ramrebol/foam/foam-extend-4.0/src/foam/lnInclude/SLListBaseI.H:218:21: error: implicitly-declared ‘constexpr Foam::SLListBase::iterator::iterator(const Foam::SLListBase::iterator&)’ is deprecated [-Werror=deprecated-copy]
218 | iterator tmp = *this;
/home/ramrebol/foam/foam-extend-4.0/src/foam/lnInclude/SLListBaseI.H:174:13: note: because ‘Foam::SLListBase::iterator’ has user-provided ‘void Foam::SLListBase::iterator:perator=(const Foam::SLListBase::iterator&)’
174 | inline void Foam::SLListBase::iterator:perator=(const iterator& iter)
/home/ramrebol/foam/foam-extend-4.0/src/foam/lnInclude/SLListBaseI.H:220:12: error: implicitly-declared ‘constexpr Foam::SLListBase::iterator::iterator(const Foam::SLListBase::iterator&)’ is deprecated [-Werror=deprecated-copy]
220 | return tmp;
/home/ramrebol/foam/foam-extend-4.0/src/foam/lnInclude/SLListBaseI.H: In member function ‘Foam::SLListBase::iterator Foam::SLListBase::begin()’:
/home/ramrebol/foam/foam-extend-4.0/src/foam/lnInclude/SLListBaseI.H:233:16: error: implicitly-declared ‘constexpr Foam::SLListBase::iterator::iterator(const Foam::SLListBase::iterator&)’ is deprecated [-Werror=deprecated-copy]
233 | return endIter_;
The above is just a part of the output, but suggests (or I suposse) that there are something deprecated in the file SLListBaseI.H (this is its link).
I think is something in the way defining... but I don't know C++ enough to fix this.
Somebody here can help me?
Thanks
ramrebol is offline   Reply With Quote
Old   September 6, 2020, 04:10
Bloerb will become famous soon enough
I'd recommend using solids4foam instead (https://bitbucket.org/philip_cardiff...se/src/master/)
Bloerb is offline   Reply With Quote
Old   September 8, 2020, 14:38
Ra Miro
Thanks Bloerb.
I had the same problem, but I could install it using docker (long live docker).
solids4foam look works awesome.
fsifoam
[FSI] fsiFoam installation problem Tomko OpenFOAM CC Toolkits for Fluid-Structure Interaction 4 July 14, 2017 15:01
[foam-extend.org] A smooth installation of foam-3.0-extend on OpenSUSE 13.1 64-bits cookcaptain OpenFOAM Installation 7 May 26, 2015 12:22
OpenFOAM 2.2.2 source pack installation on Xubuntu 13.10 zordiack OpenFOAM Installation 1 October 26, 2013 14:08
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
