Openfoam v1906 on arm64 ubuntu eoan, wont run in any directory |
#1 | |
Sultan Islam
Rep Power: 10 ![]() |
Hello foamers,
I am running into an error regarding running any foam command (blockMesh, simpleFoam, icoFoam, etc.) I am using ubuntu eoan 19.10 on arm64 running inside a container. The previous install of ubuntu Bionic running an old openfoam 4.0 ran fine, but with eoan their repo upgraded to v1906. The error I get is this: Code:
blockMesh --> FOAM FATAL ERROR : Could not find mandatory etc entry (mode=ugo) 'controlDict' -------------------------------------------------------------------------------------- Issue was solved by building from source. I build the newer v1912 and got it to work. My experiences here: Quote:
Mark Olesen
Rep Power: 40 ![]() ![]() |
Late follow up. The standard openfoam package on Ubuntu needs some additional love and care to be more universally useful. I would strongly suggest using the openfoam.com packages directly:
https://develop.openfoam.com/Develop...ompiled/debian As explained in wiki, there are a number subpackage which should liet everyone find their preferred setup. The packages will also suggest loading the openfoam-selector, which provides a convenient means of specifying your preferred openfoam version. The packages also include an openfoam shell session, to quickly use OpenFOAM applications directly. |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
[OpenFOAM.org] OpenFOAM 2.3.x on Mac OS X 10.10.1 Installation Errors | Petru | OpenFOAM Installation | 15 | December 29, 2015 12:51 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
