October 19, 2019, 11:04 |
Errno = 1 in OpenFOAM
Raffaele
Rep Power: 7 |
Goodmorning to everyone,
I have got a stupid problem with OpenFOAM that I show you in the picture. When I run in serial it doesn't give me problems but when I run in parallel he gives me this problem but the solution is the same. Can someone help me? **************** Courant Number mean: 0.0001836581 max: 0.4903904 deltaT = 0.0001543089 Time = 0.00247285841 . . . PIMPLE: Iteration 1 smoothSolver: Solving for Ux, Initial residual = 6.975489e-06, Final residual = 4.425483e-10, No Iterations 2 . . . [402d830debd6:00188] Read -1, expected 6336, errno = 1 [402d830debd6:00188] Read -1, expected 6120, errno = 1 [402d830debd6:00188] Read -1, expected 6120, errno = 1 [402d830debd6:00188] Read -1, expected 6336, errno = 1 [402d830debd6:00188] Read -1, expected 6336, errno = 1 [402d830debd6:00188] Read -1, expected 6120, errno = 1 |
October 22, 2019, 10:33 |
Raffaele
Rep Power: 7 |
No one has got a solution for this problem?
November 1, 2022, 18:35 |
Juan Salazar
Rep Power: 7 |
Apparently this is related to docker and should not be a problem. This issue is discussed here. Try to set
export OMPI_MCA_btl_vader_single_copy_mechanism=none Last edited by saladbowl; November 1, 2022 at 18:38. Reason: improving the reply |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 04:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
