Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
regarding the flow direction fixed in 'x' axis.
Old   September 25, 2019, 06:04
Default regarding the flow direction fixed in 'x' axis.
ijaz fazil
er_ijaz is on a distinguished road
I recently updated my OpenFOAM version 4.0 to 6. I'm facing an issue in the direction of flow. My flow is always pointing in x direction. Hence I tried to change the flow axis in a tutorial windaroundbuildings in simplefoam. The default wind direction was 'x' axis, so there was no issues. When I changed the Uinlet to (0 10 0) I mean the flow is in y direction, still the flow is pointing in x direction. I'm concerned about this flow direction because in my real case, I need the flow to be in 'y' axis but the flow is along 'x' axis. Is this a bug in openfoam 6? (I have attached the image of the tutorials in which I changed the flow axis to be 'y' but still in paraview glyph is along 'x' axis)
Also I tried to run an interfoam solver, initially I set the writeinterval to be 0.5 then I thought of reducing it to 0.1, when the time was around 0.2 seconds to see what happens at 0.3 seconds, instead the program terminated with error 0.1 has already completed. Is it also bug where we can't adjust or reduce the writeinterval in OpenFOAM 6?velocity_along_y_axis.png
er_ijaz is offline   Reply With Quote
Old   September 25, 2019, 07:30
Default i apologise
ijaz fazil
Hi when I looked into the velocity profile, I think no issues with the change in direction. I think I made error in looking into the vector or glyph.
but still I'm not sure why the simulation terminates if the write interval is reduced.
bugs, flow, openfoam4, openfoam6
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Can I change flow direction using UDF? newcfdone Fluent UDF and Scheme Programming 4 April 6, 2016 23:49
confusion in specifying domain flow direction and results ashwani.thakur CFX 4 February 28, 2015 07:45
perforated plate, flow direction Benfa CFX 10 August 2, 2013 08:33
Wrong direction of flow!!! hungnguyen1908 CFX 5 July 19, 2013 09:25
