Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
cyclicGgi + Finite Area Method fails to run in parallel (foam-extend 4.1). Bug?)
Old   June 12, 2018, 10:32
Default cyclicGgi + Finite Area Method fails to run in parallel (foam-extend 4.1). Bug?)
Santiago Lopez Castano
Santiago is on a distinguished road
Dear all,
So I have implemented a solver that is somewhat similar in structure to interTrackFoam, but for a whole different purpose. Anyway, when running some of my test cases, I stumbled upon some problems trying to run the case where I have a direction of periodicity in parallel. The strange thing is that the case runs quite well in serial, using cyclicGgi, but on the moment I switch to parallel, foam throws an exception from subroutine Foam::treeBoundBox (???). However, I have prepared an example case that reproduces exactly the same error, using interTrackFoam. Note that the code runs quite well in serial.
Finally, I'd like to say that I have some experience programming in the upper abstractions of foam-extend, so it will be very valuable if someone can throw me towards the correct direction in order to deal with this issue if there's any. I apologize in advance if it is just a mistake in the setup.
Many thanks,
S
Santiago is offline   Reply With Quote
cyclicggi, finite area method, intertrackfoam
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Finite area method (fac::div) fails in parallel cuba OpenFOAM Running, Solving & CFD 10 November 20, 2012 08:03
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
MPI PROBLEMS gtg627e OpenFOAM Running, Solving & CFD 20 October 5, 2007 05:02
