Reporting a bug in Allrun script on wingMotion case |
June 10, 2018, 10:00 |
#1 | ||
Iman Sabahi
Rep Power: 8 |
Hello dear all,
I encountered a simple bug which took me some time to resolve, so i thought i'd better post it here as well as report it on the OpenFOAM's original bug-reporting link. So when you run the ./Allrun script on the wingMotion case in OpenFOAM 3.0 (Ubuntu 14.04) the terminal or the log shows the following error: cp: target ‘constant/polyMesh/’ is not a directory The simpleFoam case is run without a problem, but the pimpleDyMFoam case won't run. the reason being that the "polyMesh" folder won't be copied from the simpleFoam/constant directory, so the process can't continue. The original ./Allrun script is as follows: Quote:
Regards Iman |
bug, cp command, pimpledymfoam, prallel, wingmotion |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
Parallel Moving Mesh Bug for Multi-patch Case | albcem | OpenFOAM Bugs | 17 | April 29, 2013 00:44 |
Parallel Moving Mesh Bug for Multi-patch Case | albcem | OpenFOAM | 0 | May 21, 2009 01:23 |
Possible bug in icoFoam | msrinath80 | OpenFOAM Bugs | 6 | November 19, 2007 18:35 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
