finite area method doesn't work in parallel (foam-extend-4.0) |
Andrea
Rep Power: 10 ![]() |
Hi all,
I've noted a problem with finite area solvers in parallel using foam-extend-4.0. I copied both liquidFilmFoam and surfactantFoam tutorials, adding in the system folder the decomposeParDict from incompressible/simpleFoam/pitzDaily tutorial. After blockMesh and makeFaMesh, I've decompose the case using decomposePar without a hitch. Finally, I've tried to run the case in parallel typing "runParallel surfactantFoam 4 &", getting this error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.0-4fad65ce7cac Exec : surfactantFoam -parallel Date : May 02 2017 Time : 13:03:33 Host : ManDybHig_clust PID : 5971 CtrlDict : "/stoc/andrea/OpenFOAM_EXT/andrea-4.0/tutorial/FAM/planTransport/system/controlDict" Case : /stoc/andrea/OpenFOAM_EXT/andrea-4.0/tutorial/FAM/planTransport nProcs : 4 Slaves : 3 ( ManDybHig_clust.5972 ManDybHig_clust.5973 ManDybHig_clust.5974 ) Pstream initialized with: nProcsSimpleSum : 0 commsType : nonBlocking SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 [0] [0] [0] --> FOAM FATAL ERROR: [0] otherProcNo:2 : illegal communicator -1650115904 Communicator should be within range 0..0 [0] [0] From function PstreamGlobals::checkCommunicator(const label, const label) [0] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [0] FOAM parallel run aborting [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] otherProcNo:0 : illegal communicator -1104586048 Communicator should be within range 0..0 [1] [1] From function PstreamGlobals::checkCommunicator(const label, const label) [1] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [1] FOAM parallel run aborting [1] [2] [2] [2] --> FOAM FATAL ERROR: [2] otherProcNo:0 : illegal communicator -886773056 Communicator should be within range 0..0 [2] [2] From function PstreamGlobals::checkCommunicator(const label, const label) [2] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [2] FOAM parallel run aborting [2] [3] [3] [3] --> FOAM FATAL ERROR: [3] otherProcNo:2 : illegal communicator 1469405888 Communicator should be within range 0..0 [3] [3] From function PstreamGlobals::checkCommunicator(const label, const label) [3] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [3] FOAM parallel run aborting [3] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- The above procedure successfully run using foam-extend-3.2 instead. Therefore, it should be a bug related to the last version (foam-extend-4.0). Any idea what this is and how to fix it? Best, Andrea |
Hrvoje Jasak
Rep Power: 33 ![]() |
Let me have a look and get back to you - this looks like some recent development.
Apologies, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
Hrvoje Jasak
Hi Andrea,
My bad: simple bug in comms initialisation. I have fixed it now; if you need it urgetnylu, please drop me a line. The bug fix will be pushed asap. Apologies, Hrvoje
Andrea
Hi Hrvoje,
Thank you so much for your prompt reply. I' m currently in a development stage, so I can wait for the fix. Thank you again, Andrea |
Rep Power: 9 ![]() |
Hi Andrea,
I am wondering whether you are working on the finite area or not? I am interested in applying finite area on a problem but there is not enough documentation on how to modify the solver for other applications in a proper way, even the original Ph.D. thesis Z. Tukoviīc, Finite volume method on domains of varying shape, is not available online. I am wondering whether you have any documents or would like to discuss a bit on the problem? |
Hrvoje Jasak
Sorry, I didn't realise the PhD Thesis by Tukovic is not online. We will fix this asap- it should be on http://www.fsb.hr/cfd under Dissemination. There is also a paper in Coumputers and Fluids: A moving mesh finite volume interface tracking method for surface tension dominated interfacial fluid flow Ž Tuković, H Jasak - Computers & fluids, 2012 https://scholar.google.co.uk/citatio...J:hqOjcs7Dif8C
Hrvoje Jasak
My bad: here's the link to prof. Zeljko Tukovic PhD Thesis
http://foam-extend.fsb.hr/wp-content...c_PhD_2005.pdf
Rep Power: 17 ![]() |
Cloned fe-4.0 from the git repository (git://git.code.sf.net/p/foam-extend/foam-extend-4.0) and this error is still happening with the finite area tutorials and cases.
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.0-f500917045c0 Exec : liquidFilmFoam -parallel Date : Dec 09 2017 Time : 08:51:04 Host : lazarus PID : 13964 CtrlDict : "/home/ziad/foam/ziad-4.0/run/tutorials/finiteArea/liquidFilmFoam/cylinder/system/controlDict" Case : /home/ziad/foam/ziad-4.0/run/tutorials/finiteArea/liquidFilmFoam/cylinder nProcs : 2 Slaves : 1 ( lazarus.13965 ) Pstream initialized with: nProcsSimpleSum : 0 commsType : nonBlocking SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 [0] [0] [0] --> FOAM FATAL ERROR: [0] otherProcNo:1 : illegal communicator 1 Communicator should be within range 0..0 [0] [0] From function PstreamGlobals::checkCommunicator(const label, const label) [0] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [0] FOAM parallel run aborting [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] otherProcNo:0 : illegal communicator 1 Communicator should be within range 0..0 [1] [1] From function PstreamGlobals::checkCommunicator(const label, const label) [1] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [1] FOAM parallel run aborting [1] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [lazarus:13959] 1 more process has sent help message help-mpi-api.txt / mpi-abort [lazarus:13959] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
#9 |
Turns out the repository is not up to date yet but the next release will have the fix. In the meantime you can download the updated attached file in src/finiteArea/faMesh and recompile the library from src/finiteArea (wmake libso).
Many thanks to Prof Jasak and the foam-extend development team at the University of Zagreb for making the fix available ![]() |
bug, finite area method, foam extend 4.0, parallel |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
