Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
OF-3.0.1 parallel unstable but works well in single processor
Old   January 16, 2017, 06:30
Default OF-3.0.1 parallel unstable but works well in single processor
yeharav is on a distinguished road
I posted in a different thread, but the title (and openfoam version) are no informative so I decided to open a new thread.
The domain is a simple box and
I use a hierarchical decomposition into 32 processors.
I use my own solver based on the buoyant boussinesq solver.
The simulation runs for a while with adaptable time step.
The average time step is approximately 0.23.
At ~50sec the parallel solver breaks.
That is, courant number jumps to 1e11, the same with the pressure.
When the simulation breaks I also tried using small fixed time steps (1e-3) in parallel, but to no avail.
I reconstruct and run in single and it passes. Then I decompose and run in parallel
and it runs for a while before it breaks (reaches 70).
I have tried to increase the diffusion and change the decomposition but it didn't change
the problem (just moved it to different times).
I can post the configuration files (and the solver) if it helps.
yeharav is offline   Reply With Quote
Old   January 24, 2017, 04:48
Jean bon
FlyingCat is on a distinguished road
I have the same problem (I think) on OpenFOAM-dev and OpenFOAM-4.0.
I think there is a problem with the decomposition. It seems that the decomposition of OpenFOAM is not very strong.
On a little case, the calculation was lower with more processors (even though it is possible if this is a little mesh). I changed the method of decomposition and I used scotch method, and it ran very well, quicker than with one processor. So it depends of the method of decomposition (in the decomposeParDict).
Now, I have the same problem with a bigger mesh but with scotch method. It is quicker with one processor than with 16.
Try to change the method, the problem could come from there.
FlyingCat is offline   Reply With Quote
Old   January 24, 2017, 11:06
Thanks, Yes it is a good idea.
My investigations so far have led me to think that it is the mesh quality,
but it could be the mesh decomposition as well.
When I refine my mesh and limit Co to 0.05 (with adaptive time step) things work
(but very slowly).
Old   January 24, 2017, 12:12
Jean bon
Yes, perhaps it is both. It is because of the mesh quality that the decomposition is bad. But in my case, I have already 700K cells and it is a structured grid, so I do not think it is the mesh quality (at worst, it is possible for the refinement but I will see).
Old   January 25, 2017, 02:39
Did you get this behaviour with a native OF solver (which one?)
Did you use swak4foam?
Old   January 25, 2017, 03:49
Jean bon
Yes, it is with fireFoam. And no, I do not use swak4foam.
Old   January 25, 2017, 10:31
Jean bon
See this thread :
Parallel Performance of Large Case
Do you use the GAMG solver ? I will try to run my case without this solver to see the results.
EDIT: I changed the solver but it is the same, still very low in parallel. I tried a lot of things concerning the method of decomposition and it does not work neither.
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
problem in running parallel: ./Allrun: 62: shift: can't shift that many adambarfi OpenFOAM Running, Solving & CFD 10 May 11, 2015 10:31
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
P4 1.5 or Dual P3 800EB on Gibabyte board Danial FLUENT 4 September 12, 2001 12:44
