Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Floating point exception error after icoFoam
Old   September 18, 2016, 04:39
Default Floating point exception error after icoFoam
Deepa Vedartham
Deepacfd is on a distinguished road
Hi all
After meshing the geometry in gmsh and importing it to openFoam for a particular problem, I am getting a floating point error post using icoFoam solver
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/opt/openfoam30/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so"
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
The problem geometry and description images are attached. It is a 2d geometry, there are two inlets, one outlet and the rest are walls. Since OpenFOAM by default only works with 3D mesh elements, I performed 3d meshing in gmsh software and imported it to OpenFoam. I checked the mesh on OpenFoam and there was no error. However when I changed the boundaries in boundary file in polyMesh folder generated by gmsh and accordingly changed the initial conditions in 0 folder, i got a floating point error after using icoFoam solver.
Im unable to resolve that error and produce results in ParaView.
I am currently using openfoam version 3.0.0 , gmsh version 2.13.2 and paraview version 4.4.0 all on Ubuntu 14.04 32 bit OS
I am sending the link of the problem description along with the code files. The system and 0 folders were taken from channel folder in icoFoam folder in OpenFoam.
https://drive.google.com/open?id=0B8...TZGbmI3N29KZUk
Can u figure out the error and explain it to me.
Deepacfd is offline   Reply With Quote
Old   February 10, 2017, 06:35
genderchanger is on a distinguished road
Hello Deepacfd,
Have you found the solution of your Problem?
I'm asking for, because I have excatly the same Problem.
Thanks for your reply
Best Regards
genderchanger
genderchanger is offline   Reply With Quote
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception has occurred: floating point exception [Overflow]. starlight STAR-CCM+ 4 May 4, 2016 10:08
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
