July 9, 2016, 07:38 |
OpenFoam 3.0.1: SRFSimpleFoam laminar
Rep Power: 10 |
I'm trying to run a SRFSimpleFoam case for laminar flow in OpenFoam version 3.0.1.
I have set simulationType to laminar in constant/turbulenceProperties but SRFSimpleFoam is still looking for the RAS files. When running SRFSimpleFoam I receive following error: --> FOAM FATAL IO ERROR: cannot find file file: /home/user/OpenFOAM/user-3.0.1/run/155_SRFSimpleFoam/0/nut at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting I have also found this bug report http://bugs.openfoam.org/view.php?id=1951&nbn=1 and made the proposed changes to $FOAM_SOLVERS/incompressible/simpleFoam/SRFSimpleFoam/createFields.H. Do you have any suggestions? |
July 11, 2016, 03:28 |
Anton Kidess
Rep Power: 30 |
Did you recompile after making the changes? If you're inexperienced, perhaps it's easier for you to just update to OF-4.0.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
July 11, 2016, 04:03 |
Rep Power: 10 |
No, I didn't and yes, I am. Ok, I will try that. Thanks for your help!
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
[OpenFOAM.org] Building OpenFOAM 3.0.1 on Ubuntu 16.04 - failed | erico | OpenFOAM Installation | 30 | February 2, 2017 10:24 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 20:00 |
laminar diffusion flames in OpenFOAM? | adhiraj | OpenFOAM | 3 | September 15, 2010 20:16 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
