May 20, 2015, 04:33 |
neighbour cell bug
Elisa Lafforgue
Rep Power: 11 |
When I start a blockMesh command for my Wind tunnel modelisation, I have always the same error, even if I remake the whole code I still have this error on the same cell, whatever I change in the code ... This error always appears: --> FOAM FATAL ERROR: face 24 in patch 0 does not have neighbour cell face: 4(27 218 129 28) From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.FOAM aborting However, the checkMesh command says my mesh is ok... So I wonder if this is a bug or if I am just to stupid to make a right code ... Could you help me please? ps: I use OpenFoam 2.1.1 Elisa L. Last edited by Elisa-L; May 21, 2015 at 05:20. |
May 21, 2015, 05:24 |
#2 | |
Elisa Lafforgue
Rep Power: 11 |
Hey,
As I am completely lost now, I will explain the détails of my problems, if anyone could help I'd be grateful because as it is needed for my job I really need help! My problem: I wrote a code corresponding to a simple Wind tunnel at the beggining and I slowly added geometrical caracteristics like spline and arc. My Wind tunnel worked. And now, I have to add some shutters at the inlet. So, the problems began: I had to implement the shutters in the actual inlet, so to do it the simplest way, I cut the inlet in two parts, in some way I reduced the previous "inlet" and added, before it, the part which contains the shutters. Now that I had created the points for the shutters, I had to create the blocks (the parts between the shutters) and the "walls" of all the shutters. I created it the simplest way again: first I made simple blocks and big simple faces, then it didn't work so I divided, step by step, the part with the shutters to have the same "cut lines" everywhere in this part... Now the real problem is: at the beggining I had trouble with a face, that didn't have neighbours... as shown below: Quote:
And now that I had changed all the code and even divided some parts in triangular (and so it is for the first face of the shutter faces)... I have the same message! What did I do wrong? Please help me! Even my professor can't tell! I attach my code for your consideration, some parts are in french but I don't think it is really annoying as it is just for some indications (shutter = registre). Last edited by Elisa-L; May 22, 2015 at 09:10. Reason: precisions |
block mesh, bug, cell, face, mesh |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 05:28 |
Problem/ bug in mesh.cellCells() ?? | daZigeiner | OpenFOAM Bugs | 2 | May 18, 2015 16:54 |
interFoam running blowing up | sandy13 | OpenFOAM Running, Solving & CFD | 2 | May 5, 2015 08:16 |
monitoring cell | Jane | Siemens | 2 | March 4, 2004 22:01 |
cell to cell relation | CMB | Siemens | 1 | December 4, 2003 05:05 |
