non reproducible results with respect to domain decomposition |
vinch
Rep Power: 14 ![]() |
Hi guys,
I'm doing simple tests using the application BuoyantBoussinesqPimpleFoam. It's basically the same example than the hot room given, where I added an inflow on every sides of the box. However, I did the exact same simulation on 24 processors, but specifying in system/decomposeParDict a different domain decomposition. I used the following: (24 1 1) (6 4 1) (4 6 1) I joined to this message the results of the simulations at an equal time. The plots are showing a cut in the z direction. On the left hand side, the Uz component of the velocity is given, and on the right hand side, mag(U) is given. We can see that Uz changes from a simulation to another. I also joined a decomposeParDict file I use as text file. Did anybody experienced the same problem? Is there a way to fix that? no_forcing_1.jpg no_forcing_2.jpg no_forcing_3.jpg decomposeParDict.txt |
venu
Rep Power: 7 ![]() |
Hi Vinci,
Did found the reason for the not able to reproducibility results with different processors. |
Herpes Free Engineer
Rep Power: 12 ![]() |
Could any of you provide a reproducible example for this?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
