Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Possible bug in OpenFoam Interpolation class
Old   March 5, 2014, 07:35
Default Possible bug in OpenFoam Interpolation class
Matteo
MMC15 is on a distinguished road
Hello everybody,
I'm currrently using the class interpolationCellPoint, but I experienced a strange behaviour in its usage.
I'm using this class in two different ways:
- the first, I declare an object Uinter of class interpolationCellPoint in the header file of my custom class:
#include "interpolationCellPoint.H" // need by Uinter
namespace Foam {
class myClass {
public:
...some objects...
interpolationCellPoint<vector> Uinter;
vector velInterp(point &iVelPoint,label &iVelCell);
private:
and I define it in constructor:
#include "myClass.h"
namespace Foam {
defineTypeNameAndDebug(myClass, 1);
// Default Constructor
myClass::myClass(const volVectorField& U):
    ...some definitions...
    // Set the pointer to the velocity field
    U_(U),
    // Uinter construction
    Uinter(U),
...other definitions...
where const volVectorField& U comes from my custom solver based on simpleFoam. Then in velInterp I call the interpolate member function of Uinter:
namespace Foam {
vector myClass::velInterp(point &iVelPoint,label &iVelCell)
V=Uinter.interpolate(iVelPoint, iVelCell);
return(V);
That works correctly and gives me a vector output as expected.
- the second, I declare and define the variable Uinter of class intersectioCellPoint directly inside the velInterp function, so it is no more a myClass public member, but it borns and dies directly inside the function:
namespace Foam {
interpolationCellPoint<vector> Uinter(U_);
return(V);
I obviously expect that these two methods are equivalent, but I noticed that the vectors V are different.
I can't figure out the reason for this discrepancy in the results.
Is it my fault or have I found a bug?
MMC15 is offline   Reply With Quote
Old   March 6, 2014, 06:08
Matteo
I forgot to mention that I'm using openfoam 2.2.2.
Old   March 23, 2014, 13:55
Retired Super Moderator
Bruno Santos
Greetings Matteo,
Without a complete test case (case + application source code) for easily+quickly testing this, it's very hard for anyone to be able to answer to your question(s), without taking several hours to set-up an identical code structure and test case.
Best regards,
Bruno
OpenFOAM class to represent initial boundary conditions sanatan OpenFOAM Programming & Development 1 March 20, 2011 10:16
bubbleFoam validation case balkrishna OpenFOAM Running, Solving & CFD 24 August 30, 2010 05:37
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 15:32
Cumulative patch for OpenFOAM 141 January 3rd 2007 msrinath80 OpenFOAM Bugs 6 January 4, 2008 11:12
OpenFOAM 14 stock version parallel bug msrinath80 OpenFOAM Bugs 2 May 30, 2007 15:47
