Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Advise on domain dimensions for wake turbulence simulations related to wing geometry
Old   Yesterday, 13:07
Default Advise on domain dimensions for wake turbulence simulations related to wing geometry
KG
kg_059 is on a distinguished road
Hi Guys,
I am asking for advise related to domain dimensions. I want to conduct simulations on aircraft wake turbulence. I want to model a block-shaped domain, that contains a model of a wing (a have attached a basic idea). The boundaries will be an inlet, symmetry on the side that the wing is attached to, and the rest will be openings.
I am asking for advise concerning the size of the block shaped domain in relation of the wing-geometry.
for example:
The domain should have a length of 5 times the wings chord before the wing and 50 times the wings chord behind the wing. The height of the domain should be 2 times the span of the wing und the width should be 3 times the span.
Does anyone have suggestions or experience how big the domain should be to be able to depict the wingtip-vortecies while being as small as possible to not waste computational power.
Your advise would be greatly appreciated! :-)
I have looked into the literature but have not found something useful yet...
kg_059 is offline   Reply With Quote
grid dimensions, meshing, turbulence, wake, wing
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 14:43
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
[ANSYS Meshing] Ansys not meshing internal geometry of wing jkptz7 ANSYS Meshing & Geometry 1 January 22, 2017 18:45
Closed Domain Buoyancy Flow Problem Madhatter92 CFX 6 June 20, 2016 22:05
kOmegaSST without turbulence modelling of the flow around geometry CFDnewbie147 OpenFOAM Running, Solving & CFD 7 December 5, 2013 08:29
