Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Cyclic AMI interface on mesh generated using gmsh
Old   November 27, 2024, 03:17
Default Cyclic AMI interface on mesh generated using gmsh
Divyaprakash
Divyaprakash is on a distinguished road
I want to run a simple case of a rotor rotating in a cavity. I am facing the following issue.
The circular boundary is the interface I want to use for AMI.
This boundary is shared between the two volumes (Outer and inner), which I name separately in the python script.
The interface surface tag is however shared between the two volumes. When I run gmshToFoam, I get the following error.
"Cannot interpret multiple physical surfaces associated with one surface on line number 105"
So how do i get around this issue? I have attached the script I am using to generate the mesh.
TL;DR: Is it possible to generate AMI interface on a mesh created using gmsh?
File Type: png Screenshot from 2024-11-27 12-43-54.png (68.0 KB, 1 views)
Divyaprakash is offline   Reply With Quote
ami, gmsh, interface
Actuator disk mesh generation problem with GMSH tgovoni SU2 0 August 30, 2023 09:37
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 10:33
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
