Home > Forums > Special Topics > Mesh Generation & Pre-Processing
warning: mesh with topological dimension 2 lower than space dimension 3"
Old   November 16, 2024, 13:13
Default warning: mesh with topological dimension 2 lower than space dimension 3"
James bowery
jabowery is on a distinguished road
Under what conditions would it be "topologically" questionable to have both surface and volume elements in a 3D mesh?
I get this:
"warning: mesh with topological dimension 2 lower than space dimension 3"
from sfepy regarding a simple gmsh-generated EHD mesh consisting of a truncated cone suspended in air. The EHD is to be performed only on the air volume, driven by a charge emitter at the top surface of the truncated cone and a charge sink on its base -- both surfaces -- with air flow around the side of the cone, also a surface. A gmsh surface-only rendering:
The regions:
The cone volume:
The air volume:
jabowery is offline   Reply With Quote
dimension, topology
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 11:05
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 20:53
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
