October 10, 2024, 21:31 |
Extrusion for non-uniform meshes in GMSH
Priyanshu Pokhrel
Hi everyone,
I'm new to GMSH and having some trouble with creating a 3D mesh from a surface extrusion. Here’s the situation: I have a 2D surface with non-uniform element sizes. Near the walls, the elements are much smaller—about 20 times smaller than those further away. When I extrude this surface to create a 3D mesh, I have the option to set the number of layers. From what I understand, the number of layers will control the element size in the third dimension, right? The problem is, if I choose a number of layers that matches the size of the larger elements (away from the walls), the aspect ratio of the smaller elements (near the walls) gets distorted. But if I adjust for the smaller elements, the larger ones end up being too thin and stretched. Is there a way in GMSH to control the extrusion size in the third dimension in a way that avoids messing up the aspect ratios? Any suggestions on how to tackle this would be greatly appreciated!. Thanks in advance |
extrusion, gmsh |
How to apply a turbulence model to the rhoCentralFoam solver? | arussell92 | OpenFOAM Pre-Processing | 18 | July 25, 2022 04:26 |
twoPhaseEulerFoam confined plunging jet simulation failed | ves | OpenFOAM Running, Solving & CFD | 2 | June 17, 2020 05:08 |
Fluid stuck in pipe simulating jet in crossflow | jammy4536 | OpenFOAM Running, Solving & CFD | 7 | June 2, 2020 05:55 |
Boundary Conditions | MtnRunBeachBum | OpenFOAM Pre-Processing | 1 | April 30, 2015 16:33 |
simpleFoam Floating point error (Core Dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 2 | December 31, 2013 06:57 |
