September 14, 2024, 18:27 |
Add boundary conditions of ASCII CGNS mesh
Rep Power: 17 |
Hi there,
I have a basic CGNS mesh which has mesh and solution data, but which appears to be missing the BC data... I'm able to read it in cgnsview and can see the various nodes so I believe its a valid file. I have some software which will generate meshes with the same nodes and structure for slightly perturbed geometries, so without having to study the entire spec, does anyone know the basics of how to add some boundary patches. Would it be relatively easy? I suspect it might be a case of navigating to the correct node in the file and adding a new node for the BCs with a list of the node or cells and the type of BC ... Hoping there is a relatively short answer to this. Perhaps someone even has a simple CGNS block mesh i could pull apart. Tia Cheers /Jonathan |
ascii, boundary condition, cgns, mesh |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
reverse flow in centrifugal fan blades | kalm | CFX | 20 | December 2, 2023 07:25 |
flow over cylinder in openFoam | saeed jamshidi | OpenFOAM Pre-Processing | 3 | August 11, 2023 16:16 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
